Results 1 to 6 of 6
Thread: Sharpening on Veritas Mk II machine
    Trinity County - 160 miles north of San Francisco. Redwood forest.
    159
    I have a number of tools, including some mortise chisels, that won't fit in the standard tool holder. My first attempt to set a bevel angle w/o the holder was pretty awful.
    Can the machine be used for these bigger tools? How about an axe blade?
    I don't want to go out and by a Tormek.
    Gary Curtis
    Geneseo, Illinois
    61
    Steve
    Just received mine yesterday. I didn't order extra sandpaper with it, thinking I could make my disks myself. Would this be a good idea or
    not, and have you tried it? If so what did you use for adhesive, and
    paper?
    Thanks
    Les
    Geneseo, Illinois
    61
    Quote Originally Posted by Steve Clardy View Post
    Hi Les.
    Not sure on the adhesive you would need to use if you made your own discs.
    I ordered an extra set of discs with mine when I got the machine, probably two years ago.
    I'm still on the first set. Discs last real good
    Thanks steve that was another thing I was wondering about (how long the disks last) I'm going to just order a backup set. I can't wait to have some sharp tools.
    159
    The disks sold by Lee Valley w/ the machine are 3m brand. They are called PVA-backed sanding disks and are also sold through auto refinishing supply companies. 8-inch, with a small hole in the center. A really well-stocked auto parts house might have the larger grit sizes, but probably not the finest grade. They are made for car painters.
    I wouldn't try making your own up.The disks sold at Lee Valley last a long time. The 80-grit will go forever. The 40-micron and 9 micron will clog up faster. After grinding a new bevel on 5 plane irons and 20 or so chisels, I'm going to replace my 9 micron disk. The courser grits are still going strong.
    A friend of mine gave me some LapSharp disks to try out. These have a larger hole in the center, but are otherwise similar to the Lee-Valley supplied disks. LapSharps are available down to 1, .5, .3 micron, which is really in the domain of honing. Otherwise, they offer no advantage over Lee Valley supplies and are more expensive. Cost is about $4/disk. LV cost is about $3/disk.
    When you take into account the "expendibles" costs for the different sharpening methods, the Veritas is quite economical. Scary sharp techniques can really chew a hole in your wallet.
    Gary Curtis
    Minneapolis/Grand Marais Minnesota
    181
    My buddy Charlie over at the swimming hole put this together. I copied his jig and it works great. Not brave enough to try kitchen knives yet but it works great on my schlick.http://www.sawmillcreek.org/showthre...t=33218:thumb:
    The Lap/sharp paper with sharpening compond or rouge works real well for honing an edge.
    Live Like You Mean It!!
    30,231
    Hey Tyler...good to see you pop in. Don't be a stranger.
  1. Lee Valley Veritas sale
    By fred hargis in forum Hot Deals
    Last Post: 03-28-2015, 11:29 AM
  2. Turn a machine into a variable speed machine ie drill or lathe etc.
    Last Post: 05-29-2014, 08:20 PM
  3. Veritas New Inset Vice...?
    By Stuart Ablett in forum Neander Woodworking Q&A
    Last Post: 01-02-2011, 06:49 PM
  4. 5 new Veritas rabbet planes
    By Frank Pellow in forum Neander Woodworking Q&A
    Last Post: 02-24-2010, 02:43 PM
  5. Veritas Bench Blade
    By Frank Pellow in forum New Tools
    Last Post: 12-29-2009, 07:15 PM
