Results 1 to 10 of 18
Thread: Mahogany Screen Porch
    America's Hometown
    43
    Hi,
    I have been working on a mahogany screened in porch - I think that the pictures tell it all -
    America's Hometown
    43
    And so no lonely mosquito could get in, I stapled screening under the 12 by 18' deck.... here's the pic.
    Everything is mahogany, the door is 1 1/8" thick mahogany - as well as the side panels that run floor to ceiling beside the door.
    There are 15 premeasured panels in the porch, aluminum frame and screen that were custom ordered.
    Everthing is screwed in with either stainless steel or brass. The panels - the last close - up are hand screwed together with brass screws and grommets, for easy removal and take down for winter.
    This was my first "construction" type project, and the deck railing was a first for me - I hired another contractor to help me with that. The screen porch portion felt more like cabinetmaking, and I most likely made it more complicated than it had to be, but the results were worth it.
    I know that I haven't been around, but I do check in here. Lots of good stuff going on over here.
    Thanks!
    Gail
    Long Island, NY
    71
    How great does that look. Nice work.
    Richard
    15,815
    Wow Gail, that sure looks like a nice spot to spend a lazy Sunday afternoon!
    Very nice looking wood too.
    Glad to see you around, hope you can check in more often, we always enjoy seeing what you are doing!
    499
    WOW,
    What a treat to get to work with that much hardwood.
    That's the 1st screened in porch I would like to have.
    I cannot image the cost !
    Did you mill the wood or were you able to find good milling for that much wood.
    Did you do all of this on site?
    Charlotte, NC
    1,487
    That is quite spectacular! What did you finish all that mahogany with?
    Constantine, MI
    8,006
    Wow. That is by far the nicest screen porch I've seen!
    www.wrworkshop.com
    America's Hometown
    43
    Thanks all! The lumber for the door and side panels alone was over $500.00 - this was a very expensive project. The finish on it is Penofin, was easy to work with. I did everything in the shop - milled all of the panel stock - even calculated the screen sizes prior, the installation was on site - 2 days.
    Thanks again.
    Gail
    Toronto, Ontario, CANADA
    2,332
    That's nice looking wood Gail, and your craftsmanship certainly does it justice.
    Cheers, Frank
    Very nice work indeed Gail.
    What finish did you apply?
  1. Putter Palace Porch
    By Carol Reed in forum Shop Tours
    Last Post: 08-14-2013, 06:08 PM
  2. Cypress Porch Balusters
    By Matt Hutchinson in forum Lathe Project Showcase
    Last Post: 04-03-2013, 02:50 AM
  3. Screen Porch Floor -- Suggestions?
    By Dave Richards in forum Carpentry and Construction
    Last Post: 05-23-2012, 10:16 PM
  4. Ash Porch Swing
    By Donald Stonecipher in forum Flatwork Project Showcase
    Last Post: 10-02-2009, 05:58 AM
  5. Porch ceilings
    By Jeff Horton in forum Carpentry and Construction
    Last Post: 08-30-2008, 03:02 PM
