Results 1 to 3 of 3
Thread: Pool Filter/Pump Housing Advice
    Fredericksburg, VA
    161
    I need to get some opinions from the collective wisdom here for something that I need to take care of quickly. The 'works' for our pool sit at the very back of our yard, right up against our board-on-board wooden fence. I was told when the pool was installed (Spring, '03) that I should try and build some sort of covering for the pump/filter so as to avoid any UV damage to the hoses. Well, I never quite got around to that. Now, I'm starting to see the beginnings of some hose wear, plus I'm just tired of looking at it. I want to build an enclosure that will allow easy access, but still protect everything. I need to have access all the way around the unit(s), from the sides and the top. I don't want to get too fancy. Pressure-treated wood will do. Please take a look at the pics, and possibly offer some ideas. Thanks very much in advance!!
    - Keith
    30,223
    About all I can think of would be some sort of matching lean-to shed over the pump and filter. You could hinge the roof and/or on or more walls for access, or make the whole thing like a shell that could be lifted off if necessary. Something along these lines...very rough sketch.
Name:	Pump Enclosure 800C.jpg
    15,811
    Yep, something like Vaughn put up.
    4 posts, two taller on the back, then then some cross pieces to make it all solid, then put panels on all 4 sides, you have a cordless drill, right? Well, just put 4 good screws into each panel, that way, if you need to remove them, with your cordless, it would just take a minute.
    The roof, same thing, hinge it, and use two screws to hold it down.
    Good luck!
  1. Air Filter Advice
    By Kevin Sadaj in forum General Woodworking Q&A
    Last Post: 10-22-2014, 03:47 PM
  2. to all of you housing guys and girls ....
    By jim capozzi in forum Off Topic Discussion
    Last Post: 12-27-2010, 11:17 PM
  3. Grow-Op housing
    By Mack Cameron in forum Off Topic Discussion
    Last Post: 11-29-2010, 02:52 PM
  4. Pool owner advice needed
    Last Post: 07-15-2010, 06:12 PM
  5. the incredible still cruddy housing market on LI
    Last Post: 02-18-2010, 07:38 PM
