Results 1 to 8 of 8
Thread: Poplar
    Poplar
    A friend of mine gave me several large chunks of Poplar. I started making a vase out of one of them yesterday. All that I finished so far is the outside. I planned on doing the inside today. Now that I am thinking about the grain of the wood I am not sure that it will stay together. Has anyone else turned an HF out of Poplar? If so what should I be expecting. I am turning it at about 500 RPM and the width of it is about 10" across the top.
    Thanks.
    Shawn
    Charlotte, NC
    1,487
    I haven't done this, l but I think I saw where someone wrapped their form with saran wrap to help prevent blowout. Might be worth a try!
    Shawn....I can't speak for the piece of wood you are turning but I've turned poplar without any abnormal difficulties. As stated Ed you might try wrapping it with plastic wrap or even binding it together with blue painters tape.
    Goodland, Kansas
    4,834
    Shawn I have wrapped them in saran wrap with good success. Haven't had one blow yet. The last was a maple burl. It creaked and groaned the whole time.
    Bernie W.
    Thanks guys. I went wrapped it in some shrink wrap then heated the wrap up with a heat gun to shrink it. It worked. I posted pics. in the pics. area (sorry I forgot what the name was).
    30,230
    Shawn, having now seen the pics of the poplar vase, I don't think that one was in any danger of flying apart. Still, since you had the wrap available, it didn't hurt having it on there.
    Also, I'm finding that I get better finishing cuts if I increase the speed a bit. For something like your vase I'd have probably been running between 1000 and 1200 after I got it round. Of course at higher speeds, you have to be more careful with your tool presentation, because a small glitch can become a spectacular catch.
    North Ogden, Utah
    348
    The only thing I've found different from poplar (cottonwood, aspen, willow are all about the same) is that it won't cut very clean or sand very smooth until it's good and dry. But then it's nice wood with a great caramel color to it.
    Wood Depend on what kind of Poplar you speak.... What the lumber yards call Poplar (which is a Magnolia) or Yellow Poplar... or true Poplar which is Aspin, Cotton wood, /silver poplar Lombardy poplar or a host of other woods . All them turn best when they are completely DRY , and then they turn quite well and I see no reason why they would not work for HF or Bowls or Billie Clubs or whatever you desire.
  1. POPLAR BOX BURL
    By Peter J Hay in forum Lathe Project Showcase
    Last Post: 08-10-2013, 07:28 PM
  2. about Poplar
    Last Post: 06-11-2012, 12:41 PM
  3. Pine vs Poplar
    By Tony Baideme in forum General Woodworking Q&A
    Last Post: 02-12-2011, 05:05 PM
  4. Poplar Vase
    By Bernie Weishapl in forum Lathe Project Showcase
    Last Post: 01-30-2011, 04:46 PM
  5. Is this really FAS Poplar?
    By Tim Armstrong in forum General Woodworking Q&A
    Last Post: 02-11-2007, 08:43 PM
