Results 1 to 6 of 6
Thread: 1957 Delta/Rockwell Shaper, full restored - $400 (Not Mine)
    1,289
    Reply to: sale-354002651@craigslist.org
    Date: 2007-06-17, 11:17AM EDT
    I don't have room for this machine anymore. I bought it as a pair with my tablesaw when I opened my woodworking shop. I completely disassembled and re-worked both machines, I have since moved my shop back home and can't fit the shaper in the garage.
    Single Phase wwired for 220/240
    It comes with lots of original shaper cutters, and has a 1/2" ,3/4", 3/4" adapts to a 1" spindles.
    http://websearch.about.com/gi/dynami...%2Fcities.html
    I figured someone would grab this one.
    DT
    this is a good deal!
    WNY, Buffalo Area
    873
    I've never used a shaper, so this might be a dumb question. Why is the table so big? Specifically behind where the fence mounts. I though shapers were always used with a fence inplace. Would you ever use a shaper without a fence? To me it seems dangerous given the size of the cutters used. Unlike most router tables it doesn't appear that you can adjust the fence backward away from the cutter head.
    www.tinyurl.com/thewoodshoppe
    sean, there`s many times when a person will affix jigs-n-fixturers to a shapers table instead of using the fence. the shaper, as with a router makes a fantastic pattern cutting machine, only instead of using a 3/4" bit with 1"-1-1/2" cutting length you use a straight cutter and rub coller. the back side of the table is also a great place for mounting a feeder.....tod
    WNY, Buffalo Area
    873
    Thanks Tod
    Does a rub coller work the same as a bearing on a router bit?
    Quote Originally Posted by Sean Wright View Post
    Thanks Tod
    yup, a rub collar can be of a ball bearing type or just a steel disc, they can be had in countless diameters so as to work with various cutters.
  1. Delta Rockwell 33-267 RAS
    By Dave Black in forum Old Iron
    Last Post: 06-29-2014, 04:36 PM
  2. WTB: Extended Delta/Rockwell rails
    By Darren Wright in forum Old Ads
    Last Post: 03-05-2011, 04:13 PM
  3. Delta Rockwell 37-220 jointer
    Last Post: 09-23-2009, 11:57 AM
  4. Delta/Rockwell Industrial Radial Arm Saw
    By Matt Hutchinson in forum Old Ads
    Last Post: 03-05-2009, 10:35 PM
  5. Rockwell Joiner/Plainer - $60 (Not Mine)
    By Don Taylor in forum Old Iron
    Last Post: 09-22-2007, 09:14 PM
