Results 1 to 9 of 9
Thread: Spot the Flaw
    30,230
    Spot the Flaw
    Short quiz...see if you can spot the minor flaw in this bowl. (No fair peeking at the thumbnails ahead.):
Name:	Bowl 022 - 01 800.jpg
    How about now?
Name:	Bowl 022 - 02 800.jpg
    And now?
Name:	Bowl 022 - 05 800.jpg
    One more hint:
Name:	Bowl 022 - 03 800.jpg
    This spalted alder bowl is about 9 3/4" wide by 5" tall...more wood from the lady next door. The nice bark inclusion on the side didn't survive the ride, so it's bit impractical for ice cream or peanuts. Grapefruits, maybe yes.
    The finish on the outside is once again Formby's Tung Oil mix, buffed to a nice gloss with tripoli and white diamond, then Renaissance Wax. On the inside I used the low-gloss version of the Formby's Tung Oil mix followed with a white Scotch Brite to create a matte finish. It makes for a neat contrast with the outside.
    This is another one folks will either like or not like, but that's just how things "turned" out.
Name:	Bowl 022 - 04 800.jpg
ID:	9977 Click image for larger version.
Name:	Bowl 022 - 07 800.jpg
ID:	9978 Click image for larger version.
Name:	Bowl 022 - 08 800.jpg
ID:	9979 Click image for larger version.
Name:	Bowl 022 - 10 800.jpg
ID:	9980 Click image for larger version.
Name:	Bowl 022 - 11 800.jpg
    Comments and opinions (favorable or not) are welcome. The only way I can improve is to hear what people think.
    15,815
    I think your photography skills are getting better and better!
    Nice save just the same.
    To me, the form is a little too pointy on the bottom of the bowl..........
    .....it is a minor point, and it could be the way the piece is photographed, the lighting or my eyes, but that area there, that I put the blue line, I think the form would have been just that much sweeter, if there was a bit more roundness there.
    I also understand you might have been working within the constraints of the wood that you had left
    All in all, nice piece for sure!
    30,230
    Although the sort of pointy bottom was intentional (just something I wanted to try) I agree with your curve comments Stu. Although instead of pushing the line out a bit, I think I could have pulled it in a bit, making the bowl a bit shorter, but giving more roundness to the bottom. Overall the bowl is a bit taller than I typically would have made it, but I was stretching the height to try to save the bark inclusion. Even with that in mind though, I could have lost 1/4" to 1/2" off the bottom and made it more round.
    Thanks for the compliments and the suggestion.
    s. Barrington,IL.
    127
    Vaughan I did a bowl last week that I chucked up wrong(made a NE bowl instead of a regular bowl ) and when I finished the one side is 3' high the other side about 1" . Not good for popcorn just apples or other fruit.
    Ken
    North Ogden, Utah
    348
    Well, it sure ain't gonna hold much soup!
    Incredible bowl Vaughn!
    Nicely done Vaughn! Photography is great too!
    Turning those with a large hole in them is a real experience in "faith turning"!.....You just keep keep riding the bevel on your bowl gouge all the while having faith it won't fall through the hole ....get caught ...and pulled loose from your hands just before it smacks on the head for being stupid!
    30,230
    Quote Originally Posted by Ken Fitzgerald View Post
    ...Turning those with a large hole in them is a real experience in "faith turning"!.....You just keep keep riding the bevel on your bowl gouge all the while having faith it won't fall through the hole ....get caught ...and pulled loose from your hands just before it smacks on the head for being stupid!
    You're right about the "faith turning" Ken. Fortunately on this one, the void was mostly full of bark until right before I was finished with the turning tools, so it wasn't as dicey as it could have been. I was hoping the bark inclusion would hang in there, but right at the end I got it a little thinner than it wanted to be, so a few big chunks detached. The void looked uneven that way, so I knocked out the remaining bark.
    Constantine, MI
    8,006
    It leaks.
    www.wrworkshop.com
    11,900
    Don't price by the pound.
  1. Spot the Safety Violations
    By Vaughn McMillan in forum Safety Tips
    Last Post: 03-24-2014, 04:39 PM
  2. Design Flaw
    By Dan Mooney in forum Designs, Plans and Sketches
    Last Post: 03-01-2014, 06:49 PM
  3. How Can You Spot The Amish Fisherman??
    Last Post: 02-14-2014, 06:52 AM
  4. new tune spot
    Last Post: 07-04-2010, 11:40 AM
