Sean Wright
- WNY, Buffalo Area
I have a 1.5hp Craftsman contractor's table saw. I most often use a 60 tooth cross cut blade. It is not a thin kerf. I was considering changing to a thin kerf combination blade, to give the saw a little more power, so to speak. I was considering something along the lines of Freud's LU83R thin kerf combination blade.
I find I do alot of both cross and rip cuts. That is my reason for the combination blade. What is the consensus out there..... do you change blades (have one for cross cut & one for rip) or do you use a combination? Any recomendations would be appreciated.
If my shop was big enough for a RAS I would dedicate that to cross cut and the TS to rips, but that is not the case. I do cross cut most things that are 6in or less wide on the CMS (not sliding).
