Results 1 to 7 of 7
Thread: Might get Leigh Jig...
    Kansas
    417
    ...but I was wondering how it attaches to a bench or table. I have looked on their site and either miss it or its not there. I know some of you here have it so I thought I would find out. I am looking at the D4R if it makes any difference on the model.
    Thanks
    Rise above the rest
    5,375
    Quote Originally Posted by Aaron Beaver View Post
    Thanks
    My older model has "T" slots in the underside of the main extrusion. I just drilled two holes in the bench, and used 'toilet' bolts and wing nuts to mount it.
    You could also use a "C" clamp at each end, I suppose, or permanently mount it to a plywood base and screw or clamp that to the bench.
    BTW, you're gonna really like the Leigh. Super versatility, and contrary to what you may have heard, pretty easy to set up and use. The instruction book is very clearly written.
    ďThe opposite of bravery isnít stupidity, itís conformity. Even a dead fish can go with the flow.Ē
    Roy Underhill, 2018
    Between St Joseph and Savannah, MO
    147
    ...but I was wondering how it attaches to a bench or table. I have looked on their site and either miss it or its not there. I know some of you here have it so I thought I would find out. I am looking at the D4R if it makes any difference on the model...
    I have the D4, not the D4R. They are almost identical, though.
    In the User Guide, on Page 11, Figure 1-22, you will find exactly what I did, to raise the jig to a better working position. You also will find Chapter 1 at: http://leighjigs.com/data/D4R-Ch01.pdf .
    In addition, for a particular project I did some time ago, I had to raise the jig even more, to allow me to route pins and tails on 50-inch long boards - here you see the D4 sitting on the dovetail box I made for it:
    THIS is one of the boards I was talking about :
    And yet another board, etting ready to cut the sliding dovetail socket - this photo also shows the box supporting the D4:
    The project was this changing table for our daughter, who was getting ready for our #5 granddaughter - and the boards were to assemble the carcass for the table:
    The partition is a sliding dovetail, also made on the D4, of course:
    Enjoy!
    Al
    Watch videos from Woodworking in America in Berea, KY
    New blog URL: http://sandal-woodsblog.com/
    Sandal Woods - Fine Woodworking
    We will build your heirlooms
    Kansas
    417
    Thanks guys, that answers that. I know PC's new Omnijig is coming out sometime in the next couple of months but I do not know if it will have the extra templates available like the Leigh does to do the different joints.
    How big router you need for for this, I have a PC 7518 in my table but will want another one for this jig. I know they say a router with a micro adjustment is good to use.
    Rise above the rest
    5,375
    ...How big router you need for for this, I have a PC 7518 in my table but will want another one for this jig. I know they say a router with a micro adjustment is good to use.
    I use a PC 690. It's a real workhorse, and performs quite well with the Leigh. In fact, I actually use two 690's - with the straight bit in one, and the dovetail bit in the other. The D-handle is my preference, but the regular base works just as well.
    Roy Underhill, 2018
    Kansas
    417
    One last thing. Can you do pieces over 16" or 24" depending on which jig you have. Didn't know if you could "index" the wood with the bit off of an already cut dovetail to clamp the board then continue cutting? Not saying I would ever need to, just curious if it can be done.
    Rise above the rest
    Wake Forest, NC
    292
    No, you can't do boards larger than the rated width. A Keller jig can, but not the Leigh.
  1. Leigh DT jig?
    By Al killian in forum New Tools
    Last Post: 01-04-2013, 01:40 AM
  2. Leigh 3 pc bit set
    By Rennie Heuer in forum Hot Deals
    Last Post: 04-17-2009, 02:55 AM
  3. Leigh D4 $300
    By ken werner in forum Hot Deals
    Last Post: 09-29-2008, 03:44 AM
  4. New to Me Leigh FMT
    By Alex Reid in forum New Tools
    Last Post: 03-07-2008, 01:10 AM
  5. Leigh D4
    By ray klosek in forum Old Ads
    Last Post: 11-03-2007, 07:40 PM
