Page 1 of 7 12345 ... LastLast
Results 1 to 10 of 65
Thread: Square Body Propane Gas Forge
    15,815
    Forging ahead with the new square body forge....
    I got the Isolite bricks................
    That is 7 bricks, they cost about 680 yen each, so about $5.50 each, and the ceramic tile things ($1 each) are for covering the bottom of the forge, as they are easily replaceable and should wear better than the super soft Isolite bricks.
    Thus, I'm into the forge for around $40 (not counting the other stuff I already have from the other forge I built,the gas regulator, the popane tank etc).
    This is the basic idea, with a back piece too.
    I'm going to cut the bricks a bit,to make better, tighter joints, and then I'll wrap the whole thing in fairly thin plate metal to make it durable and somewhat portable.
    To cut the blocks, I just use a hacksaw, works well, but you DO wear the blades out. Took two blades, could have taken three really, as the last cuts I was wishing for a new blade! (I only had two hacksaw blades ).
    This is what a cut brick looks like.
    The bottom two bricks cut.....
    The sides in place.........
    ........with the shelf tiles in place.
    OK, the bottom, side and top are done!
    On to the back, this took a bit of noodling and some cutting, but I like the way it turned out, I don't think I'll have much trouble with it.......
    Taken apart to give you an idea of the joint.....
    last one, need to start anohter post!
    15,815
    OK, here is the back all in place.........
    now for some shots of the "Size" of the forge.......
ID:	10319 Click image for larger version.
ID:	10320 Click image for larger version.
    It is not that big, about a 22cm x 23 cm x 23 cm cube, or just under a 10" cube.
    The actual forge size is..........
ID:	10323 Click image for larger version.
ID:	10324 Click image for larger version.
    that is 9cm x 8cm x 16.5cm deep, or just around 1200 cc, or 1 1/4 pints.
    Well that is it so far, I need to get some steel to cover it, and weld that up, then I need to work on my propane burner.
    Charleston
    917
    Looking COOL Stu. I might have to try my hand at making my own forge, if yours works out. Please keep us updated on your progress.
    15,815
    Thanks Joe!
    Tons of "GOOD" info availible online, like this guy.........
    www.zoellerforge.com
    Here is another one, a Step by Step to building a Propane Gas Burner
    Yet another one......
    How to make a Propane Forge
    Like I said, lots of good info out there!
    Alan DuBoff is offline Former Member (by the member's request)
    711
    Stu,
    That's looking good. Brick forges are one of the most flexible of all,
    I was playing around with my forge yesterday, got a stand and getting it tuned properly...yellow, I think that's pretty hot...
    (here's another one for you Joe, how I built one!;-)
    Stu,
    Are you going to totally enclose it in steel? Or just make a frame around the edges to hold them together? I was just curious how you were planning to mount the burner and/or wether it was going to enter through the top (angled) or in the side. It's looking good, that's gonna be one nice forge.
    I was trying to forge some brass this past week, to try and hand forge a saw back to make a handsaw out of...it didn't go quite as stellar as I would have liked and I got frustrated. I'm going to try the slotting method by using a small mini-mill (you can barely see it in the background on the floor, upper right of photo).
    I tried to keep the forge down at around 1300 degrees, a friend of mine helped me measure it, but we weren't too successful, it was a bit fugly...
    Inside the Beltway
    2,666
    Stu,
    that is one seriously cool little forge. So cool, I searched ebay for isolite brick... with no success
    Not that I have the time to make one, given what's happened, but still... very cool...
    Bill
    15,815
    Thanks guys!
    I was looking at it tonight, and I think I'd like to modify the design to allow me to open the back of it if I want to heat up something longer, so what I plan on doing is to make a tube of fairly thin plate, something near 1/16" that goes around the bricks, top, bottom and both sides. I think this would also have the advantage of being able to open it up to exchange bricks if one got badly damaged somehow.
    I saw this online.......
ID:	10328 Click image for larger version.
    not exactly like this, but something that would pull straight out from the back, leaving the rear of the forge open.
    I'm thinking that if the front and rear panels were even bolted in place it would be fine, I'd not be opening it up when it is hot, but then again, maybe that kind of function would be nice to have....?
    I've got to find some high heat glue that will bond the Isolite bricks to metal.......
    I know I had some stuff for motorcycles that was a stick of putty looking stuff, you cut off a section and kneaded it together, then stuck it on, in 5 or 10 minutes, it was like steel, you could even drill and tap it, and it was supposed to be high heat...........?
    I'll have to look around.
    Needs some more noodling for sure
    15,815
    Oh yeah, Bill, you can get these bricks at most pottery places, they use them to line their kilns.
    If I were you, in the US, I'd just order some of the Duroblanket stuff (or whatever it's called) I could not source it here.
    I'd then build a round forge!
    711
    Stu,
    I think the brick forge is a good idea. I think I would go for a clamshell style forge next, using brick as the floor with a clamshell over the top. That allows you to be able to lift it, place the work underneath, and put the clamshell back in place, using bricks to cover the exposed areas around the clamshell...kinda hard to explain.
    Those bricks would be fine without the metal.
    Here's one that uses metal for the top, but the bottom is all brick.
    711
    Stu,
    I ran across this forge on yahoogroups.
    Phil Roybal's Forge
    That's the same burner I have on my forge, they seem pretty popular.
  1. Buffalo Forge DP
    By Matt Hutchinson in forum Old Iron
    Last Post: 07-22-2009, 01:14 PM
  2. Conserving Propane
    By Travis Johnson in forum Carpentry and Construction
    Last Post: 12-14-2007, 10:35 PM
  3. When is a square edge not square?..............UPDATE!!!
    By Mark Rios in forum Neander Tool Questions and Show & Tell
    Last Post: 01-06-2007, 12:39 PM
  4. Suggestion for a propane heater?
    Last Post: 11-27-2006, 12:25 AM
  5. Building a forge.....?
    By Stuart Ablett in forum Neander Woodworking Q&A
    Last Post: 11-14-2006, 12:16 PM
