Results 1 to 10 of 12
Thread: Rookie learning Part 01 - Grinding
    Elgin, IL
    442
    First of all, I would like to thank everybody ahead of time. I'm sure somebody will get tired of me asking all these questions I'm going to have.
    As I'm reading my homework assignment "Woodturning - A Foundation Course" by Keith Rowley he is talking about sharp tools and every woodturner to be successful needs to learn how to do things properly.
    I have the following grinder that I've never used (picked it up at Lowe's on a closeout for $25), looked like a good deal. I also picked up a stationary stand for this.
    I'm also looking at getting something like one of these.
    http://www.pennstateind.com/store/lcgrind4.html
    http://www.woodcraft.com/family.aspx?FamilyID=1998
    The question I have is. Are the grinding wheels that are standard (grinding and white friable sharpening wheels) on the grinder sufficient for what I need to do, or do I need to get something else. I don't mind spending some money to get the correct thing, if needed.
    Also, since the grinder I have is a variable speed (2000 - 3450 RPM) - What speed should I be using?
    Or do I need a different grinder all together?
    Regards,
    Randy
    Sacramento, CA
    1,367
    That one should do reasonably well. I'd probably keep it on the lowest speed.
    I forget what grit the white wheel is, but it should be relatively suitable. The gray wheel might do for VERY rough shaping (like changing a bevel angle, or profile).
    The grinder I (and almost every turner I know personally) have is the Woodcraft Slow Speed that goes on sale for 75 from time to time. It comes with two white wheels: 60 grit and 120 grit. I use the 60 when I need to grind away a lot of steel and the 120 leaves a pretty good edge. It's my go-to wheel most of the time. Especially since I find that sharpening is a frequent task with turning.
    The Jigs you linked to are helpful. The wolverine is the most popular in my area, I think. Since I'm a tightwad, I went off and built my own jig that mimics the wolverine a bit. I have pictures here:
    http://www.sacramentoareawoodworkers...s.php?album=14
    It works very well, but I plan to rework the aluminum angle pieces. Cutting the slot was dangerous on the router table, and it isn't very smooth, so I intend to use something else. I'd found some steel pipe that fits into a larger piece that should work well.
    You'll likely get many suggestions about sharpening. Ask 5 turners about sharpening and you'll get at least 9 opinions. Honing vs. not honing is a big debate and I'll tell you up front that I don't hone - mostly because the time invested doesn't seem worth the trouble to me. I get plenty smooth cuts without it. It's what works for me
    Jason Beam
    Sacramento, CA
    Randy.....I grind on a Woodcraft slowspeed grinder. I use an Indian teardrop shaped stone to knock the burrs off my gouges. Just a couple of licks to knowck of the burrs. I do, in fact, hone my skew using a diamond hone. At the urging of Chris Barton, I spent a number of days learning to use my skew and since, fallen in love with it. It is one of, if not, my most used tools. I just bought a 5/8" and 1/ 1/4" Lacer skew and have ordered a special diamond hone for them....bigger to keep my meat hooks away from their sharp edges.
    I have the entire Wolverine jig setup and wouldn't be without it. It allows a beginner like me to spend more time learning to turn and less time learning to sharpen
    I will, however, have to learn to sharpen the Lacer skews by hand because they are curved.
    Good luck!
    Ken
    29,864
    Randy, I'm another one of the guys with the 1750 RPM grinder from Woodcraft, but yours will do just fine at the slowest speed. (A lot of guys sharpen at 3500 RPM, but I think the consensus is slower is better.)
    I also highly recommend a sharpening jig. I have the Penn State model you pointed to, and I think it's great bang for the buck. I suspect it's not quite as refined as the Wolverine jig, but functionally it's virtually identical. And at about 2/3 the cost, by the time you buy all the extra pieces for the Wolverine setup. I'd buy it again.
    I'd invest the money saved in better grinding wheels and/or a wheel balancing kit. The Oneway wheels and balancing kit are top of the line, and priced to match. I like mine, but the wallet does still sting a little bit. A set of white or pink Norton wheels are more affordable, and would be a good replacement for the wheels on your grinder (especially the darker wheel...as Jason said, that one's gonna likely to be too coarse and hard for turning tools). You might not need to replace the white wheel immediately. I also recommend a diamond wheel dresser. You can get the "T" shaped dressers pretty inexpensively, or spend more money for a single-point dresser. I went with the cheaper "T" version, and it works for me.
    And by the way, no apologies necessary for any questions like this. You're not only getting answers for yourself, but for countless others now and in the future who might have the same questions. That's what this place is here for. And before you know it, you'll be jumping in and giving answers yourself. I was in your shoes about a year ago.
    Randy......About 1 1/2 years ago Vaughn sent me a set of HF turning tools because he had no use for them. 6 months later he was turning!
    Elgin, IL
    442
    Quote Originally Posted by Ken Fitzgerald View Post
    Did you send them back?
    Randy
    Jiutepec Morelos, Mexico
    230
    "You're not only getting answers for yourself, but for countless others now and in the future who might have the same questions. "
    Vaughn, I am one of them.
    Saludos
    Alfredo
    Central NY State
    3,374
    Randy,
    We've got the same grinder. It works pretty well, and is a good starting point. Before you drop some serious cash on a wolverine, I'd humbly suggest you make your own like Jason did. My son Ben, [the turner among the two of us] is pretty happy with the home made jig I made, which is alot more crude than Jason's. [BTW, Jason, your shop is too clean].
    Seems to my simple mind that honing a turning tool is like cleaning the treads on your tires. Alot of work for little return. But then, I am a really lousy turner.
    All the best,
    Ken
    Quote Originally Posted by randy street View Post
    Randy
    Nope! They're on the diving board along with my Robert Larson's, Robert Sorby's, Hamlet Lacer's, Pinnacles, and Henry Taylor's and my Jamieson HF set............. I do believe I offered to return them and Vaughn turned it down.
    Did anybody mention that turning tools are like money?.....there is no such thing as having too much!.....or that having too many turning tools is why one doesn't have to worry about having too much money?
    Sacramento, CA
    1,367
    Quote Originally Posted by ken werner View Post
    Oh jeeze ... i gotta take pics more often ... all that is gone, now. I just cleaned things a bit the other day because I couldn't find the TS (it was under about 100bf of future furniture). Now it's kinda clean, but not quite functional yet - i have to run my dust collection ducting ... hopefully tomorrow. Then things will be a bit more useful. I don't like working without my DC
    Jason Beam
    Sacramento, CA
  1. Veneer rookie
    By Tom Wallace in forum Finishing School
    Last Post: 01-08-2015, 04:11 PM
  2. Replies: 17
    Last Post: 02-26-2014, 05:09 PM
  3. SketchUp Rookie
    By matt fonner in forum Designs, Plans and Sketches
    Last Post: 05-03-2010, 10:39 PM
  4. rookie pics
    Last Post: 09-04-2008, 05:52 AM
  5. Horor story from a rookie
    By Robert Koster in forum Lathe Project Showcase
    Last Post: 09-05-2007, 05:29 PM
