Results 1 to 10 of 10
Thread: Any Greene & Greeneologists out there? Design help needed.
    Constantine, MI
    8,001
    I'm making candle stands for our church to match the altar suite I built a couple of years ago. The design is based on a G&G hall table published in Popular Woodworking by Robert Lang.
ID:	10526 The candle stands will replace the ones shown here that are essentially an oak dowel stuck into an oak disk. The wood being used is Lyptus with bloodwood accents.
    Here is my question. I need to join the upright with the angled crossbar that holds the candles. Considering the entire design is rooted in G&G, I thought the joint should not be flush, like this, Click image for larger version.
ID:	10528 but rather have the meeting edges rounded over and softened like this, Click image for larger version.
ID:	10527. Going back to my G&G books, this seems to be the preferred method to handle a joint like this. I have also considered using a square peg or two at the joint. The joint will be a M&T.
    Here is the 'real' wood that the stands are being made from Click image for larger version.
ID:	10529 Click image for larger version.
    Opinions? Direction? Suggestions?
    www.wrworkshop.com
    535
    What I'd do:
    1. Make the lower (vertical piece) about 3/8" thinner than the angled piece, splitting the difference between the two sides. However, this might make the piece look top heavy...
    OR 2. Add a cloud lift feature to the angled piece, leaving the two the same thickness. I can't tell from the pics, but if the two are the same thickness, I wouldn't put roundovers accross the joint.
    I don't think I'd add any square pegs on that joint, but I would make it a through mortise and use two dark wedges, maybe leaving the end of the tenon a little proud and rounded.
    Probably left something out, but thats my 2 cents.
    Constantine, MI
    8,001
    Hi John,
    I thought of making the vertical a little thinner, but you're right, it might look top heavy. Perhaps if I were dealing with something a little wider in the vertical....Click image for larger version.
ID:	10532, although, it's worth a try. I'll play with my samples a little and see how it looks.
    The through mortise won't work as there will be a candle directly over the center of the joint - 7 candles in all.
    Interesting that you would not round over the joint and I'm by no means settled on the idea either. I was thinking of something like this Click image for larger version.
ID:	10533 for the joint. Soft, rounded intersecting edges.
    Perhaps I have a design flaw in keeping the slanted and vertical the same size? Thanks for your input. Give me more it something comes to mind.
    www.wrworkshop.com
    535
    Yeah, I bet you could get away with having the vertical part thinner if both were wider, like in the first picture of the banister. That sounds confusing... You could probably offset the joint inwards on the lower piece if both were wider. As to the other pic, I think those joints all have offsets, except where they meet the metal bands. I'm not sure I've ever seen any G&G pieces with a non-offset joint that had a roundover accross it, but I haven't exactly made a study of it.
    Constantine, MI
    8,001
    Quote Originally Posted by John Downey View Post
    You make good sense. Unfortunately, the candle stands, 50" from floor to cross bar, would probably not lend themselves well to being much wider.
    I have even given some thought to using the Blacker Brackets as described in Darrell Peart's book (one of my favorites). Click image for larger version.
ID:	10534 Click image for larger version.
ID:	10535The 10 degree angle might be a bit of a hassle, but....... who knows?
    www.wrworkshop.com
    Houston, Texas
    2,323
    Hi Rennie,
    If G&G preferred the roundover on most things I would round it over.
    I like the idea of some square pegs. I am happy you are involved in doing a project like this. I don't know how far along you are so I am leary of offering too many ideas. We all have opinions , direction questionable
    and suggestions??? Well how far along are you?
    Shaz
    Please join me. Register now.
    Shaz
    Here is how
    Constantine, MI
    8,001
    Quote Originally Posted by Robert Schaubhut View Post
    Hi Rennie,
    Shaz
    Jointed, planed and rough cut to length. Basically what you see in the last 2 pictures. I can post some more tomorrow.
    www.wrworkshop.com
    Houston, Texas
    2,323
    Looks good so far. Will look forward to tomorrows photos. Push on
    Shaz
    Here is how
    Constantine, MI
    8,001
    EEEEEEEK!!
    Tomorrow came and went. Busy, busy, busy. I might not get back into the shop till Wednesday!
    www.wrworkshop.com
    Houston, Texas
    2,323
    EEEEEEEK!!
    Hi Rennie,
    Stuff happens! do what you can do and don't do what you can't do.
    Enjoy the week.
    Shaz
    Shaz
    Here is how
  1. here's a video for you greene and greene guys cutting square holes
    By John Daugherty in forum General Woodworking Q&A
    Last Post: 11-13-2011, 01:14 PM
  2. Greene and Greene blanket chest almost finished
    By John Daugherty in forum Flatwork Project Showcase
    Last Post: 07-13-2009, 08:44 PM
  3. greene and greene blanket chest critique
    By John Daugherty in forum Designs, Plans and Sketches
    Last Post: 06-29-2009, 03:03 AM
  4. Design help needed...
    By Dave O'Nan in forum Designs, Plans and Sketches
    Last Post: 10-21-2007, 03:52 AM
  5. Shop Drawings for Greene & Greene Furniture
    By Alan DuBoff in forum General Woodworking Q&A
    Last Post: 11-20-2006, 02:03 PM
