Results 1 to 10 of 11
Thread: A wood question for you cutting board gurus....Vaughn???...Anyone???.........
    Central CA
    797
    Some time ago I read an article that talked about using the different types of grain in a piece of wood for cutting board surfaces. I don't remember much about the article except that it dealt with the differences of using end grain, edge grain and face grain for the cutting surface. Does anyone have any information on this concept?
    Aside from end grain, what are the pros and cons of using "edge grain" and "face grain" for the cutting surface?
    Thanks, Mark.
    Custom Bonehead.
    My diet is working good. I'm down to needing just one chair now.
    "Just think how stupid the average person is, and then realize that half of them are even stupider!" --George Carlin
    30,225
    In my experience, face grain cutting boards typically show the wood's figure the best, but they are less durable (more prone to scratching) than edge grain or end grain cutting boards. Edge grain is similar to face grain in durability (not really scratch resistant), but usually shows less of the wood's figure. End grain is usually not as "figureful" as the other two, but it is by far the more durable and scratch resistant.
    You probably already know all this, but for those who might not, if you think of the wood fibers as the bristles on a broom, with face and edge grain boards you're pushing the knife blade perpendicular into the side of the bristles, so you sever them. Once they're cut, the scratch is visible. With an end grain board, you're pushing the knife blade into the tips of the bristles, so they just move out of the way of the blade. They don't get cut, to the scratch typically disappears (unless you're really whacking the board hard with the knife). This is simir to the way a bristle dart board "heals" when you remove a dart.
    So to answer your question about end grain vs. face and edge grain...
    Pros: Usually looks better, especially if you're using fancy woods like curly maple.
    Cons: Scratches much more easily than end grain.
    And I strongly recommend not combining face/edge grain with end grain in the same cutting bard. This is what can happen:
    Myself, I would be a bit leery about using end grain in a cutting board. Maybe I am way off base here, , but I would think an unsealed end grain cutting board would soak up the blood and fluids from uncooked meats.
    The old, old mills around here in good ol New England used to have a lot of end grain floors. They would take 12 x 12 inch beams and cut them into 4 inch lengths. These end brain blocks would be laid out on the floor like a brick patio because when the machinery spilled oil and whatnot, the end grain wood would soak it right up. This not only prevented slips and falls, but also acted as a preservative. Over time those end grain floors would be a modern day equivalent of creosoted ties. Oil soaked to the core, they would certainly resist rot.
    Now this is the reason I would be leery of using end grain cutting boards...at least ones not sealed with some kind of finish.
    30,225
    Travis, in this case I think you may be off base. End grain has historically been the used for butcher blocks and other wooden cutting surfaces that get heavy daily use. Typically these surfaces are treated with mineral oil, but they're not sealed per se. There is a fair amount of debate over whether wood or plastic boards are less prone to retaining bacteria. Both types appear to be capable of retaining bacteria, but both benefit from a good washing with hot water and soap.
    Personally, I use a plastic board for raw meats, and whatever I have clean (wood or plastic) for cooked meats and veggies.
    Floydada, Tx
    1,941
    Vaughn, what about Corain for cutting boards? I have some really cool peices and wondering about that.
    30,225
    Al, I think Corian would be similar to a plastic board. Great, in other words. It's probably a little harder on the knife edge, but as far as I know, Corian works well for cutting boards. (There's a guy in my area that sells them at pretty much every arts and crafts show I've been to.)
    Floydada, Tx
    1,941
    Thanks Vaughn for the info. I have fifty pound of scraps collecting dust waiting to be cutting boards.
    Yeah I kind of thought I might be off-based. Just thought I would mention my fears though. That is typically what happens when you base ideas off emotions like fear instead of logic.
    Personally I don't know why a cutting board like that would bother me, I like my steaks and hamburgs cooked rare anyway!!
    Hi guys
    Well here is some actual research on the subject, as I read it, wood is better than plastic
    http://faculty.vetmed.ucdavis.edu/fa...ttingboard.htm
    Jay
    PS and it looks better!
    don't know if I would use Corian, I think it would have the same problems as those cited for the plastic boards and would be tougher on the blades
    30,225
    Jay, if you dig around the 'net a bit, you can find research papers that argue both sides. (There are a few links in the link I posted earlier.) I don't know which ones to believe. I agree with you, though...the wood ones look better. I still tend to use plastic for questionable stuff, mostly because I can throw it in the dishwasher in hopes of a more sterile cleaning.
    And Travis, even your rare meat is generally heated enough to kill the creeping critters living in it. It may still look bloody, but it's "sanitary" blood.
  1. Wood Whisperer - End Grain Cutting Board
    By glenn bradley in forum Flatwork Project Showcase
    Last Post: 08-30-2013, 12:17 PM
  2. End grain cutting board oil question
    Last Post: 11-27-2010, 02:53 PM
  3. Cutting Board Wood
    By Aaron Beaver in forum General Woodworking Q&A
    Last Post: 02-22-2007, 07:30 PM
  4. Wood mag Cutting Board
    By Norb Schmidt in forum Flatwork Project Showcase
    Last Post: 01-02-2007, 07:01 PM
  5. wood mag cutting board
    By John Daugherty in forum Flatwork Project Showcase
    Last Post: 12-06-2006, 01:11 AM
