Results 1 to 7 of 7
Thread: What to use under a shower base?
    Northwest Indiana
    104
    Looking for suggestion on what to use under a fiberglass shower base. Thin set? sand mix? mortar mix? any of the above, none? I need to get this bathroom done so I can get some REAL shop time.
    Thanks, Russ
    There is unrest in the forest,There is trouble with the trees
    For the maples want more sunlight,And the oaks ignore their plea's. N.Peart
    Elgin, IL
    442
    Russ,
    Check out this website. They have tons of information and are very helpful. I used them when I did our master bath.
    http://johnbridge.com/vbulletin/index.php?
    Randy
    The Heart of Dixie
    4,268
    Watched a plumber set a oversized tub in thinset. He said you never had to worry about the bottom cracking. Don't see why it wouldn't work for a shower pan too.
    Custom built boats and Kits
    Floydada, Tx
    1,941
    I have used thinset and sand. Personal fav is sand.
    A semi-dry mortar bed works wel too!
    Quote Originally Posted by Steve Clardy View Post
    Not sure.
    I set our's on concrete floor, and used several treated lumber blocks under it besides the wood blocks that were already molded onto it.
    I thought I was the only one crazy enough to try that! That's what I did and it works really well.
    Northwest Indiana
    104
    Update!
    The base has landed! Thin set did the trick. My plumber friend was impressed by the way it was down. He said that the base sound "Rock" solid. Thanks the help!
  1. attic closet bathroom reno, new shower, etc.
    By allen levine in forum Carpentry and Construction
    Last Post: 07-23-2014, 06:20 AM
  2. Bridal Shower .. almost ready ...
    By Robert Horky in forum Flatwork Project Showcase
    Last Post: 08-28-2012, 02:17 AM
  3. Reminder: Perseids meteor shower
    By ken werner in forum Off Topic Discussion
    Last Post: 08-14-2007, 01:32 AM
  4. A few projects to catch up on................#4 the steam shower
    By Mark Rios in forum Carpentry and Construction
    Last Post: 06-06-2007, 07:50 AM
  5. An interesting new project/job..........Steam shower.........
    Last Post: 04-15-2007, 04:02 PM
