Results 1 to 3 of 3
Thread: We are back............ I hope
    15,815
    From Marty the Admin guy............
    Folks,
    As many/most of you already know, the forum has been down since some time
    last evening (after midnight EST).
    I've been in contact with Bluehost (our provider) on and off all morning.
    What I learned is that last night, during a routine nightly scan of the file
    system on the actual server (machine) we run on, it was discovered that the
    file system was corrupt.
    A process was started shortly after midnight to correct the problem. This
    process 'normally' runs for about 15 minutes, corrects the problem, and
    we're back up and running. Well, the process ran for hours on end and did
    not correct the problem.
    Bluehost was running diagnostics when I first contacted them early this
    morning. They discovered that a rebuild of the entire file system was
    required, and they were unable to give me an estimate on the time it would
    require.
    Unfortunately, given the odd nature of the problem, Bluehost didn't expect
    us to be down for very long, so they didn't move us (and the hundreds of
    other sites we share the server with) to another server. Had they attempted
    to move us to an alternate server, we would have been running with a backup
    of the filesystem from the previous day. That would have created a host of
    problems all by itself!
    I apologize for this down time. In the end, I still maintain that we're
    doing pretty good. In the time we've been up, this is probably one of the
    longest down times we've experienced, and it was the hosts fault.
    I'm off to take an unscheduled/early backup of the entire forum...
    Sorry again...
    - Marty -
    Hope it all stays up now!
    Goodland, Kansas
    4,834
    Me too. Don't realize how much you miss it till it is gone.
    Bernie W.
    Thanks for all your time and efforts to keep this forum up and running. Little does one know the background efforts that keep us happy. Thanks again.
    WoodWorking, Crappie Fishing, Colts, Life is good!
  1. We are back............ I hope
    Last Post: 07-13-2007, 06:59 PM
  2. We are back............ I hope
    By Stuart Ablett in forum Handtool Project Showcase
    Last Post: 07-13-2007, 06:57 PM
  3. We are back............ I hope
    By Stuart Ablett in forum Jigs and Fixtures
    Last Post: 07-13-2007, 06:55 PM
  4. We are back............ I hope
    By Stuart Ablett in forum Carpentry and Construction
    Last Post: 07-13-2007, 06:54 PM
  5. We are back............ I hope
    By Stuart Ablett in forum Flatwork Project Showcase
