Results 1 to 3 of 3
Thread: DW Planer Carriage Lock Drift - Maintenance
    9,110
    This is a public service announcement, I was experiencing some slip on my carriage lock on my DW734. I had just PM'd the machine a couple days ago and guess I hadn't been using the DRO till today. The slip was so small I didn't notice without the DRO. Fortunately all I had been working on up to discovering the problem had a tolerance of around 1/16" or so; real rough work.
    I use a dry spray lubricant on the height screw that dries foggy. This doesn't show on the height screws which are black but on close inspection I could see that I had over sprayed onto the shiny guide posts. Five minutes of my time and a little mineral spirits cured the problem. Hope this helps others achieve a quick problem isolation or fix if they run into the same issue.
    That's my good deed for the day, now back to the shop.
    30,233
    Thanks for the heads-up, Glenn. I know DRO is digital readout, but what's PM'ing a planer?
    Odessa, Tx
    1,813
    Gotta be "Preventative Maintenance". I'll never forget that term, (drummed into our thick skulls in the Good Ole USAF).
  1. Band saw blade drift solved
    By Alan Bienlein in forum General Woodworking Q&A
    Last Post: 03-19-2012, 10:20 PM
  2. Drift Master Bandsaw Fence on Sale and Question
    Last Post: 09-20-2009, 03:02 AM
  3. Bandsaw drift question
    By Bill Antonacchio in forum General Woodworking Q&A
    Last Post: 12-30-2008, 10:22 PM
  4. horseless carriage
    By David Graham in forum Flatwork Project Showcase
    Last Post: 10-06-2008, 06:49 PM
