Results 1 to 10 of 12
Thread: Making an OSS from a drill press
    The Heart of Dixie
    4,268
    I want a spindle sander and as everyone knows they are expensive. I have been toying with an idea that I can't find a flaw in. So tell me why this wouldn't work.
    Take a drill press with a sanding spindle in it. Make a big table. Add a gear motor on the DP with a arm connected to the arm on the DP so that as it turns it raises and lowers the spindle. (think steam locomotive wheel) Other motor takes care of rotation.
    Seems simple enough to do and wouldn't have to alter the drill press. Just remove a handle maybe and replace it with a new arm. Could be a quick release joint so it could still be operated manually....
    Jeff
    Thinking out loud again.
    Custom built boats and Kits
    Constantine, MI
    8,010
    Actually, I'm sure that someone markets the kit to do exactly that. I know I saw a review on it.....maybe......3 or 4 years ago?
    As an alternative, I purchased the Ryobi OSS from HD about the time they were being discontinued - for $39! There might be some still around or on an auction site. It's a capable machine, good dust collection, and a small footprint.
    www.wrworkshop.com
    How much you planning on using it Jeff? It may be OK for occasional use but the sideways pressure on the spindle of the drill is not a part of the design for that tool so the bearings will take a strain that they are not really designed to take.
    SE Minnesota
    2,550
    I've never been a fan of using a drill press for drum sanding. Seems to me that the side loading induced by sanding would cause increased wear to bushing or bearings. This would lead to increased runout causing problems with actually drilling holes. If you could find an old used drill press that's no good for drilling, maybe a modification would be in order.
    I opted to buy the Porter-Cable OSS which is a hand held device. I used to use an acrylic plate that fit in my router table to hold the thing inverted. Later I modified the table to take a Plunge Lift from Woodpecker's so the acrylic plate didn't fit but Woodpecker's just released an aluminum plate for the P-C sander so I'm back in business. The cool thing about that plate is it takes the insert rings for the lift so I can easily adjust the gap around the drum.
    The Heart of Dixie
    4,268
    I agree about the side forces. I have an extra DP that I could dedicate to this and it uses roller bearings. Shouldn't be a problem and besides it's a 30 minute job to replace then if it did ruin them. And it would be dedicated to this. I doubt I would be drilling holes with it.
    Mainly I am just tossing around the idea. I would really like an old one, but they are not easy to find. New ones are high and frankly most new imported ones are not really repairable. When they wear out it's buy a new one, not fix it.
    Maybe a used $30-$50 model off EBay isn't a bad solution for now. Hadn't really thought of that. I have an upcoming project where I would really like to have one.
    I have a line on a nice one now but I don't expect to get it. I don't really want to spend the money now, I need to finish these other two machines first. But I am not going to turn down a good deal either.
    Honolulu, Hawaii
    1,103
    Hey guys,
    How about this? Seems somebody made one, and it looks like it would work.
    Aloha, Tony
    Attached Thumbnails Attached Thumbnails oscilating spindle sander - from a drill press (350 x 619).jpg
    Ah,,,to live in Paradise!
    Registered voting member
    SE Minnesota
    2,550
    Well there you go. That looks like just the ticket for you Jeff. I suppose if you used a floor standing DP you could get a step ladder to reach the drum.
    Odessa, Tx
    1,813
    Quote Originally Posted by Steve Clardy View Post
    Yes. Someone used to market an attachment for a drill press to make it go up and down.
    On the quill bearings, being hard it them, you could fashion a drum that had the shaft come out the bottom of it also. Then make a bracket and attach the lower part to the table. That would remove the stress from the quill bearings.
    On the bracket you mentioned Steve, all you would have to do is epoxy a bearing (that would fit the rod coming out of the bottom of the drum) into a piece of MDF (or other wood), then clamp it over the hole in the DP table and that would allow the drum to oscillate and the rod would go up and down through the bearing, yet still remove/reduce the side load. (I've thought about doing this for my DP at some point). I even thought about just connecting a small cable from the arm of the DP to a foot pedal and just pump it up and down manually, (for a while, that is, til the leg got tired of that nonsense).
    London, England
    35
    I did not think of turning the thing upside down! I use a drill press for sanding quite often. The oscillating shaft may have some advantages but for what I use it for just setting the quill at different depths works for me (if you spin the depth stop all the way around it will lock the quill down). I have a piece of MDF clamped to the table with a hole in it and that’s it... works for me. the only trouble is that it you apply too much pressure the chuck and the Morse Taper can fall out of the quill. Sort of acts as a safety valve to protect the bearings!
    Ralph
    Did I mention it rains over here?
    Sacramento, CA
    1,367
    How bout this:
    http://www.grizzly.com/products/sear...ng+drill+press
    I'm pretty sure I saw a windshield wiper motor employed for just such a task in a shopnotes at some point....
    Jason Beam
    Sacramento, CA
  1. Which drill press?
    By Paul Gallian in forum New Tools
    Last Post: 11-23-2012, 04:50 PM
  2. first drill press
    By Paul Hubbman in forum Old Iron
    Last Post: 03-31-2009, 04:39 AM
  3. New Drill Press
    By Vaughn McMillan in forum New Tools
    Last Post: 01-21-2008, 04:38 AM
  4. Drill Press
    By Bernie Weishapl in forum Turning Tool Questions and Show & Tell
    Last Post: 08-04-2007, 04:39 PM
  5. Drill Press
    By Karl Laustrup in forum New Tools
    Last Post: 02-04-2007, 06:39 PM
