Results 1 to 10 of 19
Thread: My scariest dado ever.
    Constantine, MI
    8,006
    I needed to make some half laps for two sets of legs for the candle stands I'm making for our church. I thought about doing the half laps prior to gluing up the feet (Lyptus with bloodwood accents) but to do so (to my reckoning) would require an absolutely perfect glue up. Glue ups have not always been my strong point. I wanted to do the glue up and then be able to run them over the jointer and through the planer so I could be sure they were all exactly the same width. So, that meant doing the half laps with the feet attached.
    Now, normally I'm fearless (
    yeah, right) in the shop and have a very healthy respect for my tools. My dad lost 3 fingers on his Craftsman contractor saw when I was a kid. I swore I would never do that! But I have to tell you, seeing this much blade unprotected and whizzing by so quickly had me turning a little weak in the knees.
    None the less, I took my time, clamped the workpiece tight (not shown in the photos) and said a few prayers. Success!!
ID:	10757 Click image for larger version.
ID:	10758 Click image for larger version.
    Thanks for looking!!
    We all die. The goal isn't to live forever; the goal is to create something that will. - Chuck Palahniuk
    www.wrworkshop.com
    Houston, Texas
    2,323
    Nice work Rennie.
    using the mitre gauge with that extension must have been a real help too.
    That is a lot of blade showing but your fear turned into precaution, with all saftey measures in place allowed you to escape unscathed . That is a healthy fear, nothing wrong with that. If you are still unnerved with a certain process even after all precautions are in order, stop and rethink...get help or skin that cat another way.
    Did good, NICE PIECE!
    Shaz
    Please join me. Register now.
    Shaz
    Here is how
    535
    Hey Rennie, good to hear it went well . I did one like that once for a teak door with an arched top, but I was holding the piece in a tenoning jig. Still kinda scary with that big blade all the way up.
    One question though... Why would cutting the lap joint before gluing on the accents prevent you from running it through the planer? If you were worried about the accent pieces throwing you off when you re-joint the edge indexed to the lap joint, you could always intentionally make that piece say an eigth oversize, then let your accents slide around where they want when gluing, as long as its less than the extra eigth. Then joint off the eigth in one pass so that the original indexed edge is maintained (assuming your jointer cuts straight ), and the accents are flush. Clear as mud?
    9,109
    Well done. All precautions taken (hearing and eye protection assumed). As I was once told and have never forgotten "You'll hear folks tell you to respect your tools . . . fear them, its safer". A healthy fear is implied, not the white knuckle kind. Thanks for sharing your set up and once again, well done.
    Constantine, MI
    8,006
    Quote Originally Posted by John Downey View Post
    Hi John,
    Actually, I was afraid that I might cut the dados and then, after getting all the sides jointed, find out they were too wide. Not knowing if anything would move during glue up left me thinking that if I undersized them I would be OK, but who knows? If the accent pieces moved a little too much, by the time I got them jointed flush my stock would be too narrow for the dado.
    Half laps have always been one of the difficult joints for me. Just never seem to get them tight enough or flush enough. It seemed most prudent to get everything sized as perfectly as I could and then sneak up on the dado width.
    www.wrworkshop.com
    Constantine, MI
    8,006
    Quote Originally Posted by Matt Dunlap View Post
    Looks good! Seems you followed the 10 finger rule. Anytime it looks scary, then you take precautions. Then you finish with the 10 fingers you started with.
    The rule of ten - good rule!
    Quote Originally Posted by Robert Schaubhut View Post
    Nice work Rennie.
    That is a lot of blade showing but your fear turned into precaution, with all safety measures in place allowed you to escape unscathed . That is a healthy fear, nothing wrong with that. If you are still unnerved with a certain process even after all precautions are in order, stop and rethink...get help or skin that cat another way.
    Shaz
    Thanks Shaz. After the legs are assembled I get to chop a 1" square hole in the middle of the joint to accept the tenon from the upright. That's fun for later in the week.
    Glenn,
    For this particular operation I didn't even turn on the worktunes! Just wore the head set. And yes, eye protection and being careful never to step in line with the blade. I like not bleeding. It's become a bit of a habit for me.
    www.wrworkshop.com
    535
    Aha! I missed that. Cutting the joint first does lock you into a fixed size that you then have to hit just right , not too bad if you're a little over, but what a mess if you're a little under (thats when I throw the tape measure across the room - on the bright side, I usually make mistakes often enough to never have a worn out tape )
    5,373
    This would have been the perfect place to have used a hand saw, a chisel, and a rabbet plane.
    A dado jig and a router would have worked, too, if power was really necessary.
    Either would have been less 'fearful' then the TS method.
    The opposite of bravery isnt stupidity, its conformity. Even a dead fish can go with the flow.
    Roy Underhill, 2018
    Constantine, MI
    8,006
    Ahh Jim, you're a purest.
    Yes, all you say is correct. I gave a lot of thought to using a router and a jig. I use my router often for mortises. Don't remember exactly why I decided against it. Probably my inability to make a perfect jig!
    As for the hand saw, rabbet plane and chisel. Yes, but that would have necessitated my going out and buying a good saw and plane! Since I just dropped a bunch of $$ on a new camera (gloat to follow once it arrives) I don't think the LOML would have stood still for spending another $300 or so.
    However, your point is well taken.
    www.wrworkshop.com
    WNY, Buffalo Area
    873
    Rennie,
    That sure is alot of steel showing!
    Glad to hear that you took precautions and completed it with the same number of digits that you started it with.
    www.tinyurl.com/thewoodshoppe
  1. What's Your Scariest Moment in the Shop
    Last Post: 12-09-2011, 05:22 PM
  2. The Oshlun Dado!
    By Gary Lange in forum New Tools
    Last Post: 02-23-2009, 02:58 PM
  3. WTB 6" dado set
    By patrick anderson in forum Old Ads
    Last Post: 12-05-2007, 04:14 PM
  4. Scariest Haunted House Anywhere?
    Last Post: 10-18-2007, 09:19 AM
