Results 1 to 9 of 9
Thread: Ash NE Bowl, Critique pls
    Hamilton, NY
    100
    well heres my first "true" NE bowl...
    5 1/2 w at top, base is 1 5/8, 3 in high at the highest... and about 1/4 in thick throughout... In the second to last photo if you look carefully you can see a smaaallll amount of curl... I think...
    Critique pls
    US
    51
    That turned out really nice Ben! What a nice form and the wood has cool character.
    Michigan
    2,436
    I've said it before, and I'll say it again...ya just gotta love Ash
    Seriously it looks great, someday I gotta try doing a NE, and maybe it will be out of Ash.
    30,230
    I like it Ben. It's a pretty piece of wood and you did a nice job on it. Very clean lines, IMHO. In looking at the second pic, I personally think it might look better with a bit more curve in the bottom, to better mirror the curve of the bark line. (Keep in mind that's a rookie's eye, so take my opinion with a grain of salt.) That said, it's still a great-looking bowl. How was the ash to turn? It seems it'd be pretty tough. What'd you use for the finish?
    Tokiwadai, Japan
    2,882
    Very nice, Ben.
    I would agree with Vaughn on the curve at the bottom, but I just got my chisels today, so....
    15,815
    Nice piece of Ash Ben and you did it justice for sure!
    A couple of comments.....
    These busted areas can be hidden, I'm sure you know this, DAMHIK , the easiest way I've found that looks really good is to take a junk screwdriver, heat it up red hot, and then burn edge just a bit, you can make the burnt area look VERY much like the unburnt area, again DAMHIK..........
    The second thing is the shape of the bowl, don't take this the wrong way, as I'm a newbie at this, but to my eye, the line of the bowl would look better if it was a little smaller on the bottom.........
    See the red dots? That is more the kind of line I find more pleasing to the eye.
    Again, this is just my view, and this is really a nitpick, so don't put much weight behind it
    A very nice bowl, who gets it?
    Hamilton, NY
    100
    Thanks guys!
    Poly finish, except i left the bark with nothing on it About that curve... origanily the foot was taller and bigger so the curved looked better, but once I stuck it on the jam chuck it sorta messed everything up and I had to make the foot that small, which ruined the curve, I know that just sounds like an excuse, but with a bigger foot the curved did look better.
    Stu: great Idea about the bark, do you just like push it against the bark? or a point? or flat? or what?
    keep the critique coming
    Indiana
    224
    looks nice, but I'm not a fan of NE bowls of lighter colored wood. So my critique wouldn't be one of value.
    15,815
    Yeah Ben, I just use an old crappy blade screwdriver, and use the corners, the flat the tip, whatever, to make a random pattern, it will not work so great on a large area, but the smaller chunks that come off, it works well.
    I hear you about the tennon and jamb chucks, use a donut chuck and a spacer between the inside of the bowl and the back of the donut chuck, I find various sizes of PVC pipe work well, cut to about 2" to 4" long, and then a foam pad of some sort.
    Here is the last NE I made, Mesquite and I lost some chunks, but used the burn method to hide my mistakes....
  1. Table critique (pics)
    By Kirk Constable in forum Flatwork Project Showcase
    Last Post: 06-12-2009, 09:13 PM
  2. Web site (please critique)
    By Christopher K Hartley in forum Turning Tool Questions and Show & Tell
    Last Post: 12-01-2007, 10:27 AM
  3. Please Critique my Firewood!
    Last Post: 10-25-2007, 04:17 AM
  4. Glider Design - Critique Please
    By Don Baer in forum Designs, Plans and Sketches
    Last Post: 05-25-2007, 02:14 AM
  5. Entertainment Center Critique
    By Jeremy Kargas in forum Designs, Plans and Sketches
    Last Post: 03-06-2007, 01:46 PM
