Results 1 to 10 of 10
Thread: Square Bubinga Bowl
    30,231
    Square Bubinga Bowl
    This bowl/platter/whatever you want to call it is curly bubinga. Although the curl isn't real prominent or noticeable in the pictures, there's some nice chatoyance in the wood. It started out about 10 1/2" square (14 7/8" diagonal on my 15" lathe) but by the time I fixed some twigged corners it ended up at 9 5/8" square and about 1 1/2" tall. This blank was dry, and probably the hardest, densest stuff I've turned. I turned it and started finishing it immediately. As simple as the final form is, I learned it's a tough one to cut and make look good. I had a lot of practice riding a bevel on air. And the turning was the easy part.
    I had a devil of a time getting a finish that I liked on this piece, and I'm still not 100% satisfied. The bubinga is pretty porous, and my problems started when I decided I wanted a gloss finish with no pores. Like a grand piano. I started with Formby's Tung Oil blend, sanded that off, wasn't happy, then tried a couple coats of Bullseye SealCoat (dewaxed shellac) to fill the pores, then more Tung Oil blend, with various wet sanding and dry buffing sessions (and no acceptable finish) in between, and finally a few coats of Watco rattle can lacquer...my "I give up" finish. I buffed it through the standard three stages, but the finish is still a bit more satiny than I want. I'll give the lacquer a few days to cure then rub the satin out and bring it to a higher gloss.
    I could have made a bigger round bowl out of that blank, and maybe I should have. No regrets though, and I got enough bottle stopper blanks out of the leftovers to pay for the whole blank. It just now dawned on me that I could have simply lopped the four sides off a round bowl on the bandsaw or tablesaw (with the proper jig). It would have been immensely easier on the pucker muscles. Still, having the square sides from the beginning made it easier to see the bowl thickness as I went along.
Name:	Bowl 025 - 10 800.jpg
ID:	10894 Click image for larger version.
Name:	Bowl 025 - 05 800.jpg
ID:	10895 Click image for larger version.
Name:	Bowl 025 - 08 800.jpg
ID:	10896 Click image for larger version.
Name:	Bowl 025 - 07 800.jpg
    Once again, comments and critiques are welcome.
    15,815
    Vaughn, that is VERY cool, I like them much, they sure do make a lot of noise when they get going eh?
    Luvery work!
    Constantine, MI
    8,010
    Vaughn - as always, exceptional work. I don't know how you consistently (and so frequently) turn out such beautiful work. You seem to have nearly as many hollow forms as Stu has avatars!
    We all die. The goal isn't to live forever; the goal is to create something that will. - Chuck Palahniuk
    www.wrworkshop.com
    Inside the Beltway
    2,666
    Vaughn,
    That is hugely cool. I like the thickness, the gentle curve contrasts well with the square form. Someday I gotta try that... but not in bubinga...
    Bill
    Nicely done Vaughn! I like Zinsser's dewaxed shellac on bubinga too!
    I gotta trying completing on of those. I started one and chichened out about the 3rd time I got my knuckles whacked.....
    Goodland, Kansas
    4,834
    Well done Vaughn. I really like the form. Finish looks pretty good to me.
    Bernie W.
    30,231
    Quote Originally Posted by Ken Fitzgerald View Post
    ...I started one and chichened out about the 3rd time I got my knuckles whacked.....
    I was pleasantly surprised to survive with all ten fingers and thirty knuckles. I was paying extra attention to make sure I didn't get my extremities on the wrong side of the tool rest.
    Zushi, Japan
    739
    Vaughn,
    That is a nice square bowl. For the fininsh you said you wanted a non-porous, high gloss. For the non-porous part you can use pumice or rottenstone fine abrasive powder to fill in pores and achieve a very smooth finish.
    Vaughn, I really like minimalist design. When I turn square bowls, I glue sacraficial pieces on the 4 sides that are cut away later, It makes turning and sanding a breeze. This may be considered cheating to a turning 'purest' Here's a link that explains it pretty good; Cheers, Barry http://woodturners.org/tech_tips/don...are/square.htm
    30,231
    Quote Originally Posted by Alex Reid View Post
    Vaughn,
    I've got some rottenstone and pumice, and was thinking the same thing. They may not be necessary, since I did finally get the pores full. Now I just need to work the satin into a gloss. I'm planning to start with wet 600 grit, the work my way into automotive rubbing and polishing compounds. I did a similar finish on a pool cue case and it came out nice.
    Quote Originally Posted by Barry Richardson View Post
    Thanks for the tip, Barry. I'm pretty far removed from being a purist...whatever gets the end result better, faster, or safer is a good thing.
  1. Square Bowl Tutorial Ver. 2.0
    Last Post: 04-16-2014, 09:02 PM
  2. Square bowl
    By Rich Soby in forum Turning Tool Questions and Show & Tell
    Last Post: 08-31-2011, 03:28 PM
  3. Pierced Bubinga Bowl
    By Neal Addy in forum Lathe Project Showcase
    Last Post: 02-18-2009, 02:06 PM
  4. Square Maple Bowl
    By Jeff Bower in forum Lathe Project Showcase
    Last Post: 04-19-2008, 01:01 AM
  5. square cherry bowl
    By Ben Werner in forum Lathe Project Showcase
    Last Post: 02-12-2008, 03:08 PM
