Results 1 to 6 of 6
Thread: MDF Shop Bench Finish Question
    Thomasville, GA
    6,124
    I just finished construction of support and outfeed tables around my tablesaw. I've applied the first of two coats of sealer and will sand before and after applying the second coat. I was planning to use paste wax to complete the finish process and also to provide a layer to protect from glue sticking. Would another type of wax be better; i.e., easier to apply and/or a more protective surface?
    Thanks in advance for your input.
    Bill Arnold
    9,109
    I think if you do a search you will find the highly detailed and almost mystical secret answer to this question will be answered repeatedly . . . Johnson's Paste Wax.
    Thomasville, GA
    6,124
    Well, certainly nothing "mysterical" about your response! That's what I normally use for this application. I was just looking for a lazy guy's way to get the job done!
    Bill Arnold
    Brentwood, TN
    294
    The only thing I would add is consider applying a coat or two of poly. It's much more abrasion resistant than any sealer. I too would go with JPW but, I can't seem to find it anywhere in my area.
    WNY, Buffalo Area
    873
    I would go with Johnson's Paste Wax as well.
    If you use something else, make sure that it does not contain silicone. This is commonly found in automotive waxes/polishes. Silicone will absorb in to your work pieces and will causes problems when you go to finish them.
    www.tinyurl.com/thewoodshoppe
    Thomasville, GA
    6,124
    Thanks for your input, guys. When I asked the question, I was pretty sure I'd wind up using JPW but wanted to find out if there are any good alternatives. I've used a ton of JPW over the years and my arms talk to me about it for days afterward!
    Bill Arnold
  1. Veritas Low Profile Bench Stop - Shop Made
    Last Post: 09-08-2012, 09:17 PM
  2. Shop project planning... New Bench nearly complete
    Last Post: 04-27-2009, 07:19 AM
  3. New Bench Drawers in the shop.
    By Kevin Vernon in forum Shop Tours
    Last Post: 09-22-2008, 10:54 PM
  4. Another bench question.
    By Jim O'Dell in forum Carpentry and Construction
    Last Post: 05-28-2007, 10:35 PM
  5. To finish or not to finish - That's the question!
    By Bruce Shiverdecker in forum General Woodturning Q&A
    Last Post: 01-10-2007, 04:22 AM
