Results 1 to 4 of 4
Thread: Question about SCMI sander HP
    I just picked up a 20 year old 37" 3 phase SCMI double headed sander. I'm in need of a phase converter but I need to know the horse power to select the proper size of converter. Does anyone know how many hp this sander would require? I looked on the motor but didn't see hp rating. At least I didn't see HP. Is there another name in German for HP? I had to look through a mirror and magnifing glass to see the plate. So if there is another name that would explain it's absence. By the way if someone has a converter that's no longer in use I might be interested.
    Thanks Mark
    Trinity County - 160 miles north of San Francisco. Redwood forest.
    159
    question about SCMI
    The standard measure of power in Europe is watts. On a larger machine you'll see a tag listing Kw. Wish I could tell you the conversion factor for amps/hp, but I'm out of my depth on this one.
    Gary Curtis
    A modern one runs on 10hp and I would guess that the one you have would likely be in the same range. You should look for a "Kw" rating on the motor plate. 10hp is 7.5Kw.
    (http://www.scmgb.co.uk/private/bin/a...ubcategoria=26)
    mark, mine has a machine rating of 49 amps at 220 3-phase for a single head.
  1. another drum sander question
    Last Post: 12-12-2014, 05:05 PM
  2. SCMI T130 Class shaper
    By John Rutter in forum New Tools
    Last Post: 10-15-2008, 12:15 AM
  3. Interesting SCMI edge sander
    Last Post: 10-13-2008, 03:45 AM
  4. 6 inch sander question
    Last Post: 05-04-2007, 01:35 AM
  5. Drum sander question
    By Julio Navarro in forum General Woodworking Q&A
    Last Post: 01-11-2007, 05:42 PM
