Results 1 to 4 of 4
Thread: PM2800 VS drill press
    La Habra Hts. CA
    399
    Does anyone have any input/experience with this drill press? My local woodworking/machinery supplier has it on special right now. It's variable speed, 18", 1hp, 5/8" keyless chuck, large table with slots.
    Doug
    Southern Georgia
    1,396
    Doug,
    I'll be in the market for a DP once I get the shop up and running, so I'm also interested.
    Both the 18" PM and 20" Delta's new DP's are mentioned briefly in this month's Wood mag.
    I like the Delta readout functioning as a depth readout, as well as Delta's table tilting 45 degrees forward.
    I like the PM's use of LED's to produce a crosshair to line up the bit with the workpiece.
    It seems the PM is available for purchase, but the Delta isn't...yet. Rockler has the PM2800 for the 'list' price of $800. But other sites seem to be adding a premium...NW Powertools is asking $850!
    What's your supplier asking for the PM?
    - Marty -
    Fivebraids, Inc.
    When you earnestly believe you can compensate for a lack of skill by doubling your efforts, there’s no end to what you can’t do…
    La Habra Hts. CA
    399
    I saw it on Louis and Companies flyer for $800. I also was told about the new Delta dp but was told it wouldn't be out till jan. or feb.
    Doug
    4,992
    doug-n-marty, i haven`t found the need for variable speed other than changing pulleys in over 2 decades of woodbutcherie? large tables are really nice but throat deapth and quill stroke would be the two things i`d place foremost in the quest for a drill press horsepower second.....variable speed at the bottom of the list....02 tod
  1. Drill Press
    By David Johnson in forum New Tools
    Last Post: 04-11-2014, 10:28 PM
  2. What about this drill Press?
    By Steve Southwood in forum New Tools
    Last Post: 12-24-2009, 12:05 PM
  3. My new old drill press
    By Carl Goreth in forum Old Iron
    Last Post: 04-28-2008, 03:14 AM
  4. Drill Press Add-on
    By Wes Bischel in forum General Woodworking Q&A
    Last Post: 12-13-2007, 08:40 PM
  5. My Dad's first Drill Press
    By Bart Leetch in forum Old Iron
    Last Post: 01-14-2007, 03:27 PM
