Alex Reid
- Zushi, Japan
="http://familywoodworking.org/forums/showthread.php?p=51159#post51159"]Lacer-esque Skew
Won't be long Alex and I can send you these blanks, hardened on one end, and still annealed on the other.
Very nice chisel Stu. I will try and make one similar. Many, many thanks for all the hard work you are doing. I am correct thinking the annealed end will go into the chisel handle? Are you leaving this end annealed so it is easier to work into a taper on the grinder?
