Results 1 to 10 of 11
Thread: tack cloth
    Bob Wiggins is offline Former Member (by the member's request)
    140 miles west of tulsa
    125
    tack cloth
    It seems I usually forget to pick up tack cloth when I venture to the big city and thought someone here wouldn't mind sharing a small amount of your trade secrets for home remedies tack cloth. thanks, Bob
    873
    THE TACK RAG
    by Al Carrell
    Dust is maybe the biggest enemy you'll encounter in furniture refinishing. After you've applied the finish, and it has set up, any dust particles that were on the surface of the furniture before you started are now sealed in forever. Sometimes it can look pretty bad.
    One of the keys to a better finish is to use a tack rag. These are inexpensive to buy in the paint store or paint department. However, making your own tack rags is an easy project and can save a little money, plus the fact it's not always convenient to leap into the car and go out for supplies when you're in your grungy refinishing clothes.
    For the rag part, you need a well-washed lint-free cloth made of cotton. Diapers left over from when you had babies are great. Old oxford cloth shirts are also good, but make sure to remove the buttons first. Heavy cheesecloth is all right as is any other old piece of cotton cloth.
    The first step is to cut the cloth into about men's handkerchief size. If you use pinking shears to cut with, there's less likelihood of raveling. Now dip the rag into lukewarm water and wring it out as completely as possible. Next you must saturate the rag with turpentine. You can pour some turp into a bowl and dip the cloth in. Again, ring the devil out of the rag.
    Since it's call a "tack rag", it's got to be tacky. This is done with a little varnish. Place the rag out on a flat clean surface and drip varnish all over the surface. Probably the easiest way to drip is to transfer some varnish into a clean empty plastic container with a cap in which you've punched a hole. Make the dots about every inch apart in an all over pattern. Fold the cloth together so the dots face each other. Now roll it up and wring it and knead it to spread the varnish around. Unfold and refold in another direction. Wring and knead again. The idea here is to spread the tackiness so it coats the entire cloth uniformly. Keep up the wringing and rolling and folding until it is uniformly spread.
    Test it to see if it's right by running over a surface. The tack rag should be tacky enough to pick up dust and hold it, but should not leave the surface tacky.
    The time to use the tack rag is just before you start to apply the varnish or other finish. Work just a little bit ahead of the brushing.
    When not in use, store your tack rags in a tightly sealed far. IF the rag needs restoration, add a few more drops of warm water followed by more drops of turpentine. Wring it thoroughly.
    Attack the dust with your tack rag, whether you make it or buy it and your furniture finishing will not be a hairy experience!
    I just copied the above for you, have never used it, so I can't comment on the method. I got it by googling "tack rags".
    Mack C. in Brooklin ON
    It feels great to sell a pen,
    I am a proud supporter of
    125
    Thanks Mack. After reading that process I believe my memory to pick up some when in town just got a whole lot better.
    I have heard of some using dust clothes (swiffers) which I have done but typically I just use compressed air from my air compressor
    Woodworking website owner
    http://www.awlfreeplans.com
    read the ingredients before you use stuff designed as a home cleaning aid prior to finishing
    688
    I like Norton's microfiber tack rag. It's not "tacky" but it does pick up the dust well - and when it gets dirty, you can throw it in the wash. I have a spare, so there's always one available.
    9,109
    Well used cotton as Mack describes. I have used the microfiber clothes as well with good result. They are available around here at the 99cent only stores so it's a no-brainer plus they are washable.
    499
    I get mine from Rockler. Every time I order something, I add a few of their tack clothes to bring the order up to the break point for freight.
    I also look when I am in the Rockler store and see if they are on sale. They are in plastic wrappers so they do not go bad.
    It feels like they have wax in them, but I guess that would be bad on the finish, so I don't know what they are impregnated with.
    And they are on sale for only $.89 each. Click here
    Jul 2007
    Grove City, Ohio
    57
    I use the Norton microfiber cloths or the swiffer type of dusting cloths. Of course a quick blast from the air compressor works well too.
    San Antonio, Texas
    765
    Lint free cotton cloth (old cotton shirts, etc.) and a little mineral spirits. Just needs to be a bit damp. Too much and you end up having to wait for the piece to dry and you're right back where you started.
  1. Tack rag problem....what to do now?
    By Tom Baugues in forum Finishing School
    Last Post: 06-05-2013, 07:16 PM
