Results 1 to 6 of 6
Thread: Bearing question
    Jul 2007
    DSM, IA
    5,719
    Question Bearing question
    Thanks to all that offered help on my paint questions for my lathe refurb.
    On to the next question...I'm replacing the bearings and have found that there are two kinds. Sealed/prelubed and those that can be regreased with a grease nipple. The original/current ones are pillow block bearings with grease nipples. Can I replace them with sealed/prelubed bearings and is there a big difference in the two kinds of bearings?
    thanks in advance, Jeff
    The Heart of Dixie
    4,268
    ,,,The original/current ones are pillow block bearings with grease nipples. Can I replace them with sealed/prelubed bearings and is there a big difference in the two kinds of bearings?
    Yes, No, Maybe?
    A lot of maybe's there. I would call a bearing house, give them the number off the bearings and ask them for replacements. Then they may give you the option of a sealed bearing. Their catalogs should have the equivalents and any optional one listed.
    Let me look up the supplier everyone over at OWWM is recommending. BRB
    OK took me a while to find it. Everyone that has dealt with these folks has spoken very highly of them. The girl on the phone is even keeping a list of people that have come there from OWWM. What I gather it is a long list too.
    http://www.accuratebearing.com./
    Custom built boats and Kits
    Can I ask you why you want to replace your greasable bearings with non-greasable ones? Normally people go the other way, that is they UPGRADE to greasable bearings. A shot of grease now and then drives the old moisture and contaminants out and will greatly outlast any sealed bearings.
    535
    I'm with Travis, "sealed" is a relative term when it comes to bearings and I'll take grease-ables anyday.
    I agree with Travis too! I'd use the pillow block bearigs. I've often replaced the U-joints of the 4 WD vehicles I've owned with greaseable ones. You drive it into snow or water....a few shots of grease and you are ready for the next adventure. I'd have no problem replacing them with original replacements.
    15,815
    Yep me too, if it has a zerk on it, and you remember to shoot some grease in there a few times a year (depending on use) those bearings should outlast you
  1. How do you choose a bearing
    Last Post: 08-07-2014, 09:53 PM
  2. Hitachi M12 Bearing Replacement
    Last Post: 07-20-2012, 01:02 PM
  3. Bearing Trivia
    Last Post: 04-26-2012, 07:48 PM
  4. Ball bearing Source
    By Bob Wiggins in forum General Woodworking Q&A
    Last Post: 06-22-2011, 12:06 PM
  5. Exploding bearing bit
    Last Post: 12-23-2007, 10:08 PM
