Results 1 to 9 of 9
Thread: Metal work question
    Charlotte, NC
    1,487
    Metal work question
    I had a piece on my electric window mechanism for my Jeep break yesterday and, although I was able to rig a fix for it, it would be great if I could replace the plastic part with an aluminum part. I don't have any experience with metal work and can't afford a milling machine, but I was wondering if I got an x/y vise for the DP, could I do some light milling with it? If so can I just chuck an end mill in the jacobs chuck?
    Albuquerque, New Mexico
    1,099
    Ed, a lot depends on the geometry of the part but yes, you can do light milling as you describe. One thing to be wary of is the drill chuck can come loose in the quill from side load and from vibration. When that happens things can get very exciting!
    DAMHIKT!
    friend...if you have one."
    one."
    Charlotte, NC
    1,487
    Quote Originally Posted by Bruce Page View Post
    DAMHIKT!
    Thanks for the heads up! Don't know if I will try anything, unless I need to fix this part again!
    Alan DuBoff is offline Former Member (by the member's request)
    711
    Sure you can, and if you use aluminum it will cut easy and can be cut on your table/band saw.
    What's the part look like?
    DAMHIKT!
    been there-done that!.........when i install chucks on a morse taper on a tai-chi drillpress like i use i`ll clean both halfs of the taper with lacquer thinner then spit on the male part of the taper before driving them together.
    don`t side load for a few days......from that point on the taper should be rusted in place, so well that i`ve had to use an air hammer to drive the wedge in order to remove a chuck...not advisable for a "good" drillpress but for the cheapies like i use it works well.
    Charlotte, NC
    1,487
    There's not much to the part. It is part of the window regulator that the 2 cables mount in using swaged ends. This is a real rough sketch of the part.
    1,099
    That should be easy enough to do. Of course you won’t have the square corners at the end of the channel that your sketch shows.
    one."
    711
    Ed,
    I think you can do that on your drill press by using an endmill on a piece of aluminum. Just go slow.
    Charlotte, NC
    1,487
    Thanks guys! If my rigged fix fails, I'll see about trying this. May even try it if I come up with other bright ideas!
  1. Back Home After Some Metal Work!
    By Bill Arnold in forum Off Topic Discussion
    Last Post: 01-23-2015, 07:42 PM
  2. Gun Metal
    Last Post: 08-19-2014, 09:23 PM
  3. New Tig / stick welder & some metal work
    By Bryan Cowing in forum Off Topic Discussion
    Last Post: 03-13-2014, 09:27 AM
  4. I'm Looking To Buy a New Metal Cut-Off Saw......
    Last Post: 04-27-2013, 01:01 AM
  5. Question about Metal Roofing
    Last Post: 10-26-2010, 12:34 AM
