Results 1 to 2 of 2
Thread: Drum Sander Ideas
    Drum Sander Ideas
    I have this half-thought out design to fabricate and machine a drum sander.
    What i would like to do is build a drum sander that is spring loaded and self-propelled by its own motor. It would pivot down on a off-road type trailer axel that I have seen that would keep the drum in contact with wood at all times. (For those that know what a Forwarder is, that is the Axel arrangement I am thinking of).
    The wood would be fed via my planer and then on the last pass, a light cut with the planer would be taken, the sander pulled down and started and thus I would be planing and sanding all in one step.
    My question is though, how would you attach the sandpaper to the drum? I was thinking of using a piece of 4 inch PVC pipe, but I do have access to an engine lathe. I would like the sand paper to be easily removed so I could switch out grits, but maybe that is asking too much.
    Any thoughts on this crazy idea?
    PS: This is a picture of a forwarder. ...
    hold downs! on either side of your drum, not for the paper but to keep the wood flat as it passes under the drum. it`s pretty likely that you`ll get a rippled finish anyway unless you design in a way to adjust the head in relation to the bed.....do a bar napkin sketch. it`ll be lots easier for an ol` hillbilly to understand.
  1. 16/32 drum sander
    By Philip Rose in forum Classified Ads
    Last Post: 08-29-2012, 10:33 PM
  2. Drum sander
    By Bill McQueen in forum New Tools
    Last Post: 04-22-2012, 04:51 AM
  3. Drum Sander.....?
    Last Post: 10-23-2011, 03:40 PM
  4. drum sander
    Last Post: 03-02-2011, 03:30 AM
  5. Belt Sander vs a Drum (thickness) Sander
    By Ken Close in forum New Tools
    Last Post: 11-26-2007, 01:36 PM
