Results 1 to 10 of 12
Thread: Opinion on Rojek MSP310M
    Heathrow, FL
    91
    I am thinking of buying the Rojek MSP310M because of it's small size and 12" jointing capacity. I am not familiar with the quality of the brand so any info on the company or that particular machine would be appreciated. For those not familiar, it is a jointer/planer combo machine.
    The one plus for me and a possible downside is the short jointer bed. I don't think it would be a problem with the little that I do but opinions would be welcome.
    http://www.rojekusa.com/PHP/msp310m.php
    Brian
    Brian,
    I am not familier with Rojek, but you will like haveing a 12" jointer combo. If you buy thiis Jointer/planer, be sure to order it with the Taresa head. It will give you a smooth cut and very easy blade changeing.
    While you are looking, check out the Min Max. I will admit my bias, but I have had good luck with mine.
    Brian
    Heathrow, FL
    91
    Thanks Brian but all others are out of my price range. The Rojek at $2500 delivered seemed pretty reasonable and peaked my interest.
    Being I am a byrd dealer, I would end up putting a Byrd Shelix head on the machine.
    Brian
    brian, a couple months ago i stopped in at techmark.....the rojek distributors for the usa....although the equipment isn`t up to the minimax-felder standards it is good solid stuff......and the staff is four star.....i think that you`d be quite pleased with the equipment especially the bang for bucks you`ll get......i`m a nonstocking delta/pm/jet dealer and unless you up the ante by lots, your 2500 would be well spent on the rojek equipment.....02 tod
    Heathrow, FL
    91
    Thanks Tod, I appreciate the info.
    I have a Powermatic 15" planer and 8" jointer now and am happy with the machines. I just need some space and the 12" jointer does sound nice.
    Any opinion on the short beds?
    Brian
    brian, i don`t use a jointer so really can`t offer any sage advice
    Heathrow, FL
    91
    Well heck if you don't need a jointer I should not have to worry about bed length. I assume you either use a planer with sled or a hand plane neither of which haave long beds.
    Brian
    15,816
    Naw, Tod buys flat wood!
    Heathrow, FL
    91
    Now there's an idea. The wholesaler I buy from doesn't get much more for S4S from what I remember.
    Brian
    brian, my non-use of a jointer has caused somewhat of a stir when i bring it up ........i straightline on either the slider or bandsaw...as far as "face-jointing" i feel it`s a terrible waste of time and lumber......if i where to try and face joint a piece of 1x stock with a 3/8" twist in it i`d only have 3/8" of usable stock remaining.........most stuff that i build has boards glued together holding eachother in line so if i pick up a board that has a twist or cup that would normally require face jointing i`ll either cut it smaller to remove the defect or glue it into an assembly where it has no choice but to behave. by and large if a fellow wants to face joint his stock and retain 3/4" of usable material he must purchase 5/4 stock to do so...with lumber prices where they are it just doesn`t make sense to me.....tod
  1. Second opinion shop cat
    By Dave Trask in forum Off Topic Discussion
    Last Post: 01-17-2009, 07:36 PM
  2. Rojek Sliding Tablesaw for sale
    By Scott Thornton in forum Old Ads
    Last Post: 08-26-2007, 08:41 PM
