Page 1 of 4 1234 LastLast
Results 1 to 10 of 40
Thread: Call for Ideas
    SE Minnesota
    2,503
    Call for Ideas
    This is for those of you using SketchUp and desiring to become more proficient. It's also for those who haven't used it but want to. You have to help me so I can help you. Here's the deal. Give me some ideas of things you'd like to see done up as tutorials. Post them in this thread and I'll work on them as I have time.
    I assume since I have moderator status I could make this a sticky. If I figure that out, I'll do it so this one stays at the top. Also, as I complete requested tutorials I'll edit your posts with a link to the thread containing the tutorial so that others can find it. How's that sound?
    15,774
    OK, one that I failed on was making a pipe, with a 3rd hole in it. See this: http://familywoodworking.org/public_...read.php?t=495
    Tried and tired, but it would not work.
    Oh, threads on a bolt See this: http://familywoodworking.org/public_...=4873#post4873
    Last edited by Dave Richards; 11-24-2006 at 02:48 PM. Reason: Edited to add links to related tutorials. dr
    SE Minnesota
    2,503
    Stu, a hole in a pipe? As in drilled in from the side? Do you want it to go all the way through or just in to make a tee? a wye?
    Threads? Do you want to actually see the threads or would indicating threads be enough?
    15,774
    Quote Originally Posted by Dave Richards View Post
    Like a T or a wye, please.
    Ah.... yes?
    Dunno the difference....
    Houston, Texas
    2,323
    This all sounds quite considerate.
    Thank you Dave.
    Please join me. Register now.
    Shaz
    Here is how
    29,864
    This is very elementary, but one thing that seems somewhat hit or miss for me is moving one object into a specific location next to another. For example, I'll draw two boxes, then if I try to put the two boxes adjacent to each other, sometimes I spend a couple of minutes getting the one I'm moving into the proper position. They'll look aligned on one axis, then I rotate and see the second box is a half mile down the road. I'm sure I'm missing something basic, and likely others are too.
    Thanks for all your help, Dave.
    See here for tutorial: http://familywoodworking.org/public_...read.php?t=585
    Last edited by Dave Richards; 11-29-2006 at 01:00 PM. Reason: added link to tutorial
    SE Minnesota
    2,503
    I'll work up something Vaughn.
    The Heart of Dixie
    4,268
    Another basic one. I follow the instructions (yes I read the help files) and try to draw some construction lines but they never show up. I made sure they are visible but hidden but the little buggers still hide.
    I think the will help Vaughn because I was wanting them to align something too.
    See this: http://familywoodworking.org/public_...read.php?t=580
    Last edited by Dave Richards; 11-29-2006 at 12:59 PM. Reason: Added link to tutorial
    Sketchup...ya know I tryed that once upon a time and i was impressed but didn't really have the time to learn it. Now I think if David is going to be around I might reconsider it since I will be doing a little sheet work in cabinets to give ppl a look at what they will be getting. Gonna tutor Dave
    Now I guess I will have to down load it via dial up
    Reg
    SE Minnesota
    2,503
    Reg, if you can find a friend with a fast connection, download the software on their computer and save it to a pen drive or other portable memory device. Those things are getting to be pretty cheap--probably less expensive than your time to download via dialup.
  1. maybe I should call this #17?
    By hu lowery in forum Lathe Project Showcase
    Last Post: 06-23-2013, 06:46 PM
  2. What would you call this and where can I buy one?
    By John Pollman in forum Off Topic Discussion
    Last Post: 03-29-2011, 12:41 AM
  3. Sometimes your better off to call a pro.
    By Jeff Horton in forum Off Topic Discussion
    Last Post: 05-27-2008, 09:12 PM
  4. Who to call?
    By Steve Ash in forum Off Topic Discussion
    Last Post: 04-07-2007, 12:55 AM
  5. What do you call this?
    By Jeff Horton in forum Turning Tool Questions and Show & Tell
    Last Post: 03-17-2007, 08:08 PM
