Results 1 to 5 of 5
Thread: Insert for Jet JWTS-10 table saw
    Jun 2007
    New Jersey
    75
    I need a zero clearance & a dado insert for my Jet JWTS-10 table saw. Any suggestions on where the best place to buy one might be?
    Thanks
    Dennis
    Look in your scrap bin for some MDF then tape it to your existing throat plate and use a pattern tracing router bit to copy exact the shape of your existing. then place it in the hole, tape it in place, slide the fence over the corner of the plate (but not over the blade) and turn on the saw, slowly raise the blade through the MDF and you have just made your own. Easier and cheaper than buying.
    Lake City, Florida
    498
    I purchased two UHMW inserts, they were both warped on arrival. By the time I got them flat I could have done what Bill said and been just as good (if not better) and cheaper. Live and learn.
    Tony, BCE '75
    Jun 2007
    New Jersey
    75
    Bill
    Thanks, I finally got around to doing the ZCI, I made 2 plus a dado insert, it was quick, easy & inexpensive
    Thanks again
    Dennis
    Odessa, Tx
    1,813
    Quote Originally Posted by Tony Falotico View Post
    I did worse than you, Tony, I bought 3 at a WW show and they were flat when I bought them, but by the time I got around to fitting them to the saw, they were so warped I just put them back on the shelf and made my own. I did save them for other uses when I needed a small piece of UHMW for a jig or something. I have since found that when I need something slick, Harbor freight often has a sale for under $9.00 on their cutting boards and knife sets, so I use the cutting boards for that, and surprisingly, none of those pieces have warped, go figure.
  1. table saw insert
    By edward alexander in forum Jigs and Fixtures
    Last Post: 05-11-2009, 01:18 PM
  2. Router table insert
    By Matt Dimon in forum General Woodworking Q&A
    Last Post: 01-02-2009, 06:34 PM
  3. Router Table + Insert
    By Bruce Niceley in forum General Woodworking Q&A
    Last Post: 12-30-2008, 11:49 PM
  4. Table Saw Zero Clearance Insert (ZCI)
    By jim crockett in forum General Woodworking Q&A
    Last Post: 02-18-2008, 02:00 AM
  5. Table saw insert question
    By Tom Williams in forum New Tools
    Last Post: 10-07-2007, 04:47 PM
