Results 1 to 10 of 11
Thread: Traditional Grind on a bowl gouge.....
    15,815
    After seeing what Bernie had to say about the Traditional grind on a bowl gouge, I went and did a bit of reading up on it, in books (gasp!) and the net.
    I then destroyed a lousy piece of Ginko wood I had roughed out some time ago!.
ID:	11405 Click image for larger version.
ID:	11406 Click image for larger version.
    Here is the tip, with my interpretation of a "Traditional Grind", the gouge is a 1/4" Hamlet.
ID:	11408 Click image for larger version.
    Here is how I hold it in use.
    I seem to get some fairly decent cuts from it, nice fine curlies!!
    here is a cut I've done only halfway, the wood, the Ginko is REALLY soft and hard to get a nice clean cut, the rough part is where I've done a normal cut with a normal bowl gouge, that was nice and sharp, but on this soft stuff, it still cut poorly............
    ....the smooth part of the cut was accomplished with the traditionally ground bowl gouge, I think the difference is rather dramatic.
    Here is that section of the bowl with the cuts finished. I also spritzed the surface with water.
    15,815
    OK the rest of this has little to do with the traditional grind bowl gouge, but with the fate of this crappy piece of wood I was trying to work....
    Once I started to get thin, and I was doing the finishing cuts on the inside, spritzing the surface with water, the bowl began to crack
    BIG cracks.....
ID:	11413 Click image for larger version.
ID:	11414 Click image for larger version.
    I tried to fix it, I drilled a hole to stop the crack, then I filled it with instant coffee cystals and glued everything with CA glue.............
ID:	11416 Click image for larger version.
ID:	11417 Click image for larger version.
ID:	11418 Click image for larger version.
    It then proceeded to crack in about ten other places
    I turned the natural edge off as that was getting really warped and wobbling around then I just gave up and started to spin it as thin as I could, just for practice..........
    I did get a lot of practice and it was kind of fun turning it to the explosive point.....
    In the end, I got some good practice, I learned a fair bit and I had some fun too. The wood was not worth the trouble of brining to a finish, but it provided me with a laugh and a giggle...........
    The right place for this one, no save here!
    So if you have an extra bowl gouge kicking around, give this traditional grind a chance, you just might like it!
    Thanks for the info Stu. It looks like you should have saved the bowl and used it for a lampshade Are you serious about the coffee crystals? I haven't heard of that before.
    Jun 2007
    Largo, Florida (The Jewel of Senile)
    27
    Stu:
    Great post and good information about the gouge grind. I keep a bowl gouge at 60 for the same "inside bowl transition" purpose. Like you said, it really helps with final cuts on some of the more tear-out prone woods.
    I really like the way you write your photo-tutorials, and appreciate your willingness to teach what you have learned - as well as to show your mishaps.
    As I tell my kids - it's OK to make a mistake if you learn from it... not that it's ever happened to me, but...
    -Steven
    My lathe is my therapist
    Quote Originally Posted by Shawn Lakes View Post
    Shawn.....If a bowl develops wide cracks I often use crushed instant coffee crystals to color clear epoxy and use epoxy to fill the crack. Others I know including Stu use instant coffee crystals and CA to fill cracks. The coffee crystals just give it a very dark brown color.
    15,815
    Thanks guys!
    The coffee crystals soak in to the glue, giving it the dark color, and it does not then looks "so much" like "glue"
    Jiutepec Morelos, Mexico
    230
    a silly question
    Stu,
    why did you spritze the surface with water?
    Regards
    Alfredo
    15,815
    Quote Originally Posted by Alfredo Rodriguez Garcia View Post
    Stu,
    Regards
    Alfredo
    I needed a shower..........
    The water on the surface of the wood, will make the wood swell a bit and stand up a bit more, this will make it easier to get nice smooth cuts.
    PS, ain't no "Silly" questions, ask them all!
    230
    Gracias
    Thanks Stu
    Goodland, Kansas
    4,834
    Stu looks like you made a good save. A lot of times I save the sanding dust to mix with epoxy. That works pretty well. I also use the conventional grind and spritz with water on the final couple of cuts.
    Bernie W.
  1. Bent my bowl gouge.. a 5/8" bowl gouge
    By Chuck Ellis in forum General Woodturning Q&A
    Last Post: 09-01-2010, 12:57 PM
  2. When to use a traditional grind or fingernail grind on bowl grouges.
    By Joe Penney in forum General Woodturning Q&A
    Last Post: 01-04-2009, 03:53 AM
  3. Need a new Bowl Gouge
    Last Post: 05-05-2007, 09:18 PM
  4. Bowl Gouge
    By Bernie Weishapl in forum Turning Tool Questions and Show & Tell
    Last Post: 02-22-2007, 11:15 PM
  5. Sharpening bowl gouge on the cheap
    By Dario Octaviano in forum Turning Tool Questions and Show & Tell
    Last Post: 01-31-2007, 07:57 PM
