Results 1 to 3 of 3
Thread: Quick question diamonds
    17,514
    what are the diamnods on the tape rule for they are around 19'' and go from there????/
    Central Ohio
    72
    They’re for laying out I-joists or floor trusses which are rated for ≈19” spacings. If you multiply the distance by 5 you’ll come up with 96” which is a sheet of flooring.
    Wes
    Its a great spacing to be honest with you. As Wes said they are for truss layouts when you feel 2 feet is to far and 16 is a little heavy. Basically over an 8 foot span you can save one truss. It does not sound like much, but on a big home it can add up.
    I have used the layout successfully for sleepers on my concrete floor. I laid the sleepers down and then laid hardwood flooring over the sleeps spaced at 19.2 inches. Another great application is strapping layout on basement walls or ceilings. The great thing is, you can get 2 feet insulation stuffed up into the space without difficulty. Its not so cramped though that it compresses the insulation too much.
  1. Quick question about finishing a table top
    By Roger Tulk in forum Finishing School
    Last Post: 12-08-2013, 02:17 PM
  2. Quick Question About Caulking
    By Alex Reid in forum Carpentry and Construction
    Last Post: 04-17-2011, 12:58 AM
  3. 8 Black Diamonds
    By Dewey Torres in forum Lathe Project Showcase
    Last Post: 03-22-2009, 08:37 PM
  4. Quick question
    By Richard Leshner in forum Off Topic Discussion
    Last Post: 11-27-2006, 12:53 AM
  5. Replies: 11
    Last Post: 11-26-2006, 04:25 PM
