Results 1 to 3 of 3
Thread: Shop Fire Safety
    Shop Fire Safety
    It took three weeks for my local oil dealer to deliver a tank and get heat inside my shop, but today I am finally working up wood without freezing my fingers off.
    Still as nice as this is, it kind of scares me. While I have a well installed forced hot air propane furnace in my shop now, its still basically a controlled fire. Since my shop is detached from my house by 150 feet, I would like to install a smoke detector out there, but have it make its alarm inside my house. That way if there is a fire in the middle of the night, I will be alerted to it a lot quicker. (My shop will have constant heat).
    Does anyone know how hard this will be to do? Can something like this be purchased, or do I have to modify a regular smoke detector? If they do make such a detector, how expensive are they?
    Steve Clardy Guest
    Maybe wire two smoke alarms together in tandem?
    Monroe, MI
    470
    I just installed a complete alarm system to protect the house and shop. The shop is a separate partition so they can be armed and disarmed separately. Only 4 conductors were necessary between the shop and house panel. I used heat detectors--alarm company wouldn't monitor smoke detectors because of the sawdust issue.
  1. safety in the shop
    By Paul Gallian in forum Off Topic Discussion
    Last Post: 01-07-2013, 07:14 PM
  2. shop question for the fire fighters!
    By larry merlau in forum Shop Tours
    Last Post: 12-10-2012, 12:37 AM
  3. Sparkproofing/ fire retarding a wooden shop?
    By Dave Black in forum Off Topic Discussion
    Last Post: 06-24-2010, 01:55 PM
  4. Shop safety
    Last Post: 01-11-2010, 04:55 PM
  5. Buffalo(NY) Fire Department's Carpenters' Shop
    By Sean Wright in forum Shop Tours
    Last Post: 11-30-2007, 01:47 AM
