Results 1 to 6 of 6
Thread: Maple UFO Bowl
    30,225
    Maple UFO Bowl
    Everybody needs to turn one UFO in their lifetime. I'm guessing this is mine. Hard maple, about 8 3/4" x 3". Finished with low gloss tung oil blend, and I'll buff it out in another day or so. It's got a crack in it (see the last pic) that I tried to soak some CA into, and it's smooth to the touch, but it's still visible. Since there wasn't a whole lot of visual stuff going on with this piece of wood, I burned the lip just for something to look at.
Name:	Bowl 028 - 05 800.jpg
ID:	11521 Click image for larger version.
Name:	Bowl 028 - 03 800.jpg
ID:	11522 Click image for larger version.
Name:	Bowl 028 - 01 800.jpg
    Comments and critiques are welcome as always.
    Constantine, MI
    8,006
    OK. It seems that every time I log in Vaughn has another HF posted. What's up with that?
    Vaughn - do you have a job? Are you spending 20 hours a day in the shop?
    All kidding aside, I like your UFO. If I had not sold my lathe a year or so ago I'd be tempted to try a HF. Fortunately, I've already put something else on the real estate the lathe occupied, so I'm safe....for the time being.
    We all die. The goal isn't to live forever; the goal is to create something that will. - Chuck Palahniuk
    www.wrworkshop.com
    Charlotte, NC
    1,487
    Looks good! Now you need to add three little legs to the bottom so it has landing gear!
    Vaughn..........Very nicely done!
    Question....what's your wall thickness? I turned an HF shaped similarly but more oval....it's wall thickness was about 1/8-3/16"....I got cracks in it...wasn't sure if it happened due to heating during the sanding process?.....
    Goodland, Kansas
    4,834
    Great looking bowl Vaughn. I like the form and the finish. Very well done.
    Bernie W.
    30,225
    Quote Originally Posted by Ken Fitzgerald View Post
    ...Question....what's your wall thickness? I turned an HF shaped similarly but more oval....it's wall thickness was about 1/8-3/16"....I got cracks in it...wasn't sure if it happened due to heating during the sanding process?.....
    It's about 3/16" thick. The crack on this one showed up when I unwrapped it a month or so after the DNA bath.
  1. 2 recent turnings - maple bowl, square quilted maple platter.
    By Chip Sutherland in forum Lathe Project Showcase
    Last Post: 04-03-2013, 03:22 AM
  2. Maple bowl
    By Fred Belknap in forum Lathe Project Showcase
    Last Post: 10-03-2012, 08:56 PM
  3. Maple bowl
    By Drew Watson in forum Lathe Project Showcase
    Last Post: 12-09-2009, 08:08 AM
  4. Maple Bowl
    By Jim DeLaney in forum Turning Tool Questions and Show & Tell
    Last Post: 10-20-2008, 03:34 AM
  5. Maple bowl
    By Curt Fuller in forum Lathe Project Showcase
    Last Post: 03-28-2007, 09:19 PM
