Results 1 to 8 of 8
Thread: simple question
    Southern Louisiana
    947
    simple question
    i know this is simple but how do i display my sketchup models on the forum? like uploading a pic but its the model screen shot instead
    thanks
    chris
    couldn`t begin to offer advice.......heck i can barely type
    Wake Forest, NC
    292
    Do an export and make it a jpg or bmp. Then you can post it as a picture.
    File - Export - 2D image
    SE Minnesota
    2,527
    Chris, do you want to do a screen shot showing the drawing window and maybe the toolbars? Or do you just want a picture of the model you are drawing? If the latter, use Travis's advice. If the former, you can use another application to make a screen grab. I use HyperSnap and another application the name of which escapes me at the moment. The mystery application is the one I use for capturing video, too.
    I did a quick search and this was the first free screen grab software I got a link to. No idea how well it works but its free.
    http://www.traction-software.co.uk/screengrabpro/
    Sacramento, CA
    1,367
    If you're using any recent version of windows, you can also do screen grabs without any other software...
    alt+PrtScn will capture the current window in your clipboard. Then you can open Paint (start > programs > accessories > Paint) and ctrl+v to paste it into Paint. Save it as a JPG or BMP file and off you go!
    Jason Beam
    Sacramento, CA
    30,129
    Another alternative to screen grab software (if you're on a Windows PC)...
    Click on the window you want to capture, then while holding down the <Alt> key, press the <PrtScn> (print screen) key. Then, open up Microsoft Paint and select Paste fro the Edit menu. That puts your screen capture in the Paint window. Save the file as a .jpg file, then resize it (like you would a photograph) to a max size of 800 pixels wide or high.
    If you're simply exporting the SketchUp drawing, as Travis mentioned, in SU select File | Export | 2D Graphic, and you can save it as a .jpg file. By default, the exported file will be bigger than the 800 pixel limit here on Family Woodworking. But if you click the "Options" button at the bottom of the dialog box where you specify the name for the new .jpg file you're exporting, you can specify a width of 800 pixels, so you won't have to resize the file after saving it. You can also move the "Compression" slider to about the halfway point to reduce the file size as well.
    Oops...I see Jason was faster on the draw.
    Southern Louisiana
    947
    thanks
    awesome help as always
    well, except for that hillbilly...but, at least he chimed in
    thanks everyone, i'll post the drawing in my thread about width of stairs in the construction forum....heck i'll post it here too
    thanks
    chris
    Southern Louisiana
    947
    ok, here goes
    let's see if i can get this thing to attach
    what you are looking at is a rough sketch of how i am considering building the stair case in my house. for more info see the construction forum at this thread
    http://familywoodworking.org/forums/...ead.php?t=5015
    thanks again for the help
    chris
  1. a simple way to die
    By hu lowery in forum Safety Tips
    Last Post: 07-05-2014, 07:35 PM
  2. Simple elm HF
    Last Post: 06-11-2012, 01:04 PM
  3. Spiral head for Jointer? Just simple question...
    By Brian Altop in forum General Woodworking Q&A
    Last Post: 02-17-2011, 08:15 PM
  4. Just a simple pen
    By Tom Baugues in forum Lathe Project Showcase
    Last Post: 10-29-2010, 04:47 PM
  5. pen box? anyone have plans for a simple wooden box, really simple?
    By allen levine in forum Turning Tool Questions and Show & Tell
    Last Post: 12-11-2009, 06:29 PM
