Results 1 to 5 of 5
Thread: Dave
    Kansas
    417
    Dave
    Similar to this, but with an ellipse as I described. Actually the arc might work as I have it drawn I just would like to see it the other way.
    Thanks
    Rise above the rest
    SE Minnesota
    2,550
    Aaron, I see. Start by drawing a circle centered above the rectangle. Use the scale tool to mash it into an ellipse. Move the ellipse down over the rectangle as desired. Select both the rectangle and the ellipse and run Intersect with selected. Delete the unwanted lines. Push/Pull to thickness.
    Howzat?
    Kansas
    417
    Quote Originally Posted by Dave Richards View Post
    Howzat?
    I get an error that says not intersections found. ??
    I was able to scale it to make it an ellipse and move it but can't intersect.
    *****update******
    not sure what happened but I did it again and it worked fine. Thanks
    Rise above the rest
    SE Minnesota
    2,550
    I knew you'd get it.
    Houston, Texas
    2,323
    Just like in the movie "Dave" (which I really like) Dave can help us make it happen. Thanks Dave...!!!
    Now, back to the budget cuts!
    Please join me. Register now.
    Shaz
    Here is how
  1. Calling Dave Richards.....Paging Dave Richards......
    By Ken Fitzgerald in forum Designs, Plans and Sketches
    Last Post: 12-06-2012, 06:03 PM
  2. Here you go Dave
    By Bob Gibson in forum Off Topic Discussion
    Last Post: 10-09-2011, 01:29 AM
  3. Calling Dave Richards! Dave, what's your twenty?
    By Bill Lantry in forum Off Topic Discussion
    Last Post: 07-11-2008, 09:46 PM
  4. OK Dave I need some help
    By Robert Mickley in forum Designs, Plans and Sketches
    Last Post: 01-28-2008, 02:25 AM
