Thanks to Kevin G., a tip he gave a while back. I ordered a 5 gal. pail of denatured alcohol from Ace Hardware. Ordering this way it works out to less than $10 a gal.. Buying it per gal. the price varies between $11 and as high as $17 per gal.
If you should order the 5 gal. pail, they have two brands, you want the Parks brand (not the Crown brand). Parks is primarily ethanol, to where the Crown is a 50/50 split of ethanol and methanol.
Kudos to Dave Smith for all the hard work he put into the Alcky method of drying wood.
