Page 1 of 10 12345 ... LastLast
Results 1 to 10 of 92
Thread: Backless chair/stool with sculpted seat
    Catalunya
    4,640
    Hi there, after three wonderfull weeks of holidays ( I apologize for not even saying a proper farewell) during which I've tidied up my workshop, and done a lot of woodworking (at last!!) I'm on the way of making the chair of the included sketch.
    As I wasn't sure how to proceed I've made a half full size mock-up in scrap salvaged wood from machinery packaging that I will post tomorrow together with some questions that I hope some of you more experienced than me will take the time to answer.
    As a token here it goes the preliminary sketch.
    Any comments suggestions will be greatly appreciated.
    Thanks in advance.
    Best regards,
    Toni
    30,231
    Ooh...I'm looking forward to seeing this one take shape. Looks like it's going to be a very nice piece. More from Toni the Artist, who happens to also do woodworking.
    I like your sketch, also. The software you are using makes it look almost hand-drawn. (I envy your excellent drawing abilities.)
    Catalunya
    4,640
    Thanks Vaughnn,
    But I'm just Toni, a fellow woodworker, that gets more from this forum that gives to it. I'll be always in debt for all the things I learn here.
    BTW. the software I'm using to draw is called IFITISNOT WHATYOUWANTDOITAGAINANDAGAIN is is on release 1.0 although there are some patches available
    Best regards,
    Toni
    30,231
    ...BTW. the software I'm using to draw is called IFITISNOT WHATYOUWANTDOITAGAINANDAGAIN is is on release 1.0 although there are some patches available
    That made me laugh. Especially the part about the patches. I think I could use a few of those myself.
    Catalunya
    4,640
    I'm glad I made you laugh BTW If you envy my drawing abilities I envy your musical ones so we are breaking even aren't we?
    Best regards,
    Toni
    688
    Hola Tony!
    What an interesting project!
    One thought that comes to mind is that the glue-ups (expecially on the mitered legs) will be challenging. Save your curved cut-offs to use to make clamping blocks!
    Hope you will post lots of pictures of your progress.
    Jess
    WNY, Buffalo Area
    873
    Toni,
    After seeing your coffee table, I can't wait to see how this project turns out!
    www.tinyurl.com/thewoodshoppe
    Catalunya
    4,640
    Hi Jesse.
    Yes you are right. The joinery is what I foresee will be the most challenging part, so I count with your help and the help from other fellow woodworkers to solve it.
    Wait for the initial pics of the mock-up that I'll post tomorrow.
    Best regards,
    Toni
    Odessa, Tx
    1,813
    This is going to be a really nice project, Toni. I love the design. For the joint between the front legs and seat frame, maybe either a tenon on the leg and a mortise in the rail, or.....maybe a stopped sliding dovetail about 3/4 of the length of the face of the joint so the dovetail wouldn't be seen?????? Either would give a lot of glue surface for strength with a proper fit, (and a real challenge to the "Joinery Skills" too if the sliding dovetail is used).
    What kind of wood are you going to make it from, the same as your Table?
    I will enjoy following this project.
    Catalunya
    4,640
    Well… as promised here there are a few pics of the state of the process.
    As I have no idea how a chair is made, and this is my first attempt ever;
    I started by drawing and cutting out from cardboard a full size set of templates of the side view ( sorry no pics) and cut the rail and front and back legs, out of salvaged pine wood from heavy machinery packaging.
    At this time as what I wanted was to check proportions, size and design I didn’t bother about any joinery because I don’t know which one should or will use, anything that would hold the pieces together would serve.
    As a matter of fact I did use a spline on the mitered ( or is it mitred?) joint of the front leg, checking at the same time how would it look if it was made of different colour.
    I glued the half seat as well, although at this time on the pic the front part of it was missing. In the final chair it will be made of a maximum two pieces joined in the centre by its length as usual not as depicted here
    Then I shaped the back and the back leg together.
ID:	11776Click image for larger version.
    Marked what would be removed from the inside to accept anybody’s bottom.
    Shaped it and tested. As the edge of the back was 90º with the seat it made an uncomfortable pressure about 3-5 inches below my belt so I decided to fill the gap with plaster, and giving it a rounded shape. I did it this way because it was faster than gluing a scrap of wood and carving it.
ID:	11779Click image for larger version.
    Rounded the inner part of the front and back legs.
ID:	11781Click image for larger version.
    Marked eyeballing the concave areas of the sculpted seat and carved them away until they felt right. (Continued in part II)
    Best regards,
    Toni
  1. Carve Chair Seat With the Tablesaw
    By Charles Hans in forum Jigs and Fixtures
    Last Post: 03-02-2014, 03:36 AM
  2. Kitchen step stool / chair
    Last Post: 05-09-2012, 08:46 PM
  3. A Ladder Back Chair with a Rush Seat
    Last Post: 04-09-2011, 09:54 PM
  4. A prototype Morris-inspired Outdoor Chair and Stool
    Last Post: 04-29-2010, 11:22 AM
  5. can this seat be saved?
    Last Post: 11-13-2009, 01:52 AM
