Results 1 to 10 of 10
Thread: computer question about .pdf & .jpg
    11,874
    Lotsa good computer savy folks here. Gotta question: Other than scanning as a photo, is there a way to convert a .pdf file to .jpg?
    I couldn't figure out a way and had to resort to the ole scanner.
    Constantine, MI
    7,964
    There will probably be 10 better answers to follow, but here's my (less than computer geek) approach.
    First, if you have Acrobat (the program not the reader) you can simply choose "Save As" and designate the file type as jpg.
    If you have only the reader (and I believe the above mentioned function is not available) you could try pasting the pdf into a PowerPoint slide and then saving the slide as a jpg file.
    Like I said, there are probably better ways...
    www.wrworkshop.com
    Palm Beach Gardens, Florida
    185
    Or, you could just selectively choose the jpg image and when it becomes "greyed out" right click on the image and select copy. You then have that specific image on your clipboard and should be able to paste it just about anywhere.
    You can also do this with a block of text, or if you really want to select the entire PDF doc and do the above.
    Regards,
    Bill Antonacchio
    9,088
    Another answer that only helps if you have Acrobat or Photoshop. Both can read PDF's and do a number of "Save As" conversions. If quality is not too important (a pic to post here vs. a wedding photo for the mantle for example), selecting the image, performing a 'copy' to the clipboard and pasting it into MS Powerpoint and then doing a "Save As" (selecting .jpg) will work.
    11,874
    If only I had PowerPoint vv I'll try the copy to PS Elements, see if that works.
    Monroe, MI
    470
    Another option I've used is to take a screen shot of the PDF (Press alt-prtscr) and paste it into an image editor.
    1,289
    Quote Originally Posted by Matt Meiser View Post
    This works very well on the Mac. Shift-Command-4 allows me to select my borders and do a screen copy and I have it set up to save as a jpg. The result is a perfect picture much smaller than a scan. Rather than mess with Graphic Converter etc. I just use the saved screen shot. It is always a good looking picture and prints perfect.
    DT
    Tokiwadai, Japan
    2,882
    Don,
    Just open the .pdf by double clicking. With the window open, select "Print", click on the PDF button and select "PDF to iPhoto... WaLa, .jpgs in iPhoto ready to view, edit, print, email or post.
    A PDF on the Festool MFT. 4 pages...4 .jpg pics.
    Attachment 11751
    Attachment 11752
    Attachment 11753
    Attachment 11754
    11,874
    Greg. That's embarrassingly simple. Thanks.
    1,289
    Quote Originally Posted by Greg Cook View Post
    Don,
    Attachment 11751
    Attachment 11752
    Attachment 11753
    Attachment 11754
    Thanks Greg but when I try that it says saving to iPhoto is not supported within print. (Even though it is listed) It does however tell you to go to file: "save as." That works just as you described. I'm using version 8 and couldn't find anything in the preferences to fix that.
    It's just as well, I don't care for iPhoto. That group of programs, iTunes, iPhoto etc. would be wonderful but for having to import everything to it's own data bases and storing 3 or four copies of everything. I prefer to use something like Graphic Converter or Viewit and work with the data where I want it to be. Never did like a program to take over. I like doing it myself.
    I often make PDF files from a "Word" document exactly as you describe but for some reason it doesn't want to do it the other way around.
    DT
  1. Computer Speed Question
    Last Post: 11-21-2014, 05:48 AM
  2. Computer Question
    By Paul Douglass in forum Off Topic Discussion
    Last Post: 09-16-2014, 06:26 PM
  3. Computer Question
    Last Post: 03-02-2013, 12:24 AM
  4. Computer Techie Question
    Last Post: 09-12-2011, 10:47 PM
  5. Computer hookup question
    By Steve Clardy in forum Off Topic Discussion
    Last Post: 03-05-2007, 12:26 AM
