Results 1 to 10 of 14
Thread: Sanding the INSIDE............????
    15,815
    OK, how do you guys sand the inside of a hollow form?
    Pics of the various solutions will get bonus marks
    I've actually used my fingers in the areas closest to the mouth.....My Jamieson tool has a teardrop shaped scraping blade I use to scrape it things smooth.....if that fails....Then I paint the inside with black acrylic paint to hide what I can't reach.
    30,233
    OK, how do you guys sand the inside of a hollow form?...
    Verrrrrry carefully.
    For the parts I can reach, like right inside the rim, I use these:
    I'm very careful and use a light touch at slow speeds. I've also found that by folding the paper into a triangle with overlapping ends (see the pic), it helps my fingers grip the paper, and it's abrasive on both sides.
Name:	Folded Sandpaper 800.jpg
    If the opening is big enough, I use one of these. I call it the Sandpaper on a Stick:
    For cases where the bowl sander won't fit, I use these:
    I generally fold a small piece of sandpaper over a piece of closed-cell foam, then clamp it with the hemostats. Be sure you don't put your fingers through the holes in the handle when you're using it though.
    I find that sanding the inside of a piece can take about as long as hollowing it out. I'm not a complete purist, though. I figure if you can't see it or feel it by reaching inside with a finger, then it doesn't necessarily require sanding.
    Steve Clardy Guest
    9,110
    That's easy. Just sand before assembly
    30,233
    Quote Originally Posted by Steve Clardy View Post
    Long skinny fingers
    Man, this place is thick with comedians.
    Drums, PA
    292
    Besides the excellent tips Vaughn showed us, I use finger tips
    I CA glue on a piece of sand paper and away I go
    15,815
    Hey Ron, that is a great idea!
    North West Indiana
    6,136
    I noticed the only person Stuart took seriously was Ron!
    Drums, PA
    292
    Quote Originally Posted by Jonathan Shively View Post
    It's because I have an honest face.
  1. Inside-out Ornament
    By Billy Burt in forum Lathe Project Showcase
    Last Post: 12-09-2012, 08:42 PM
  2. how do you finish the inside??
    By neil mackay in forum General Woodturning Q&A
    Last Post: 07-26-2011, 03:05 PM
  3. Only Hunters need look inside
    Last Post: 02-25-2011, 02:15 AM
  4. Uh...I'll be working inside for a while...
    By Greg Cook in forum Off Topic Discussion
    Last Post: 03-31-2008, 12:23 AM
  5. My Inside Hunting Dog
    Last Post: 02-23-2008, 10:49 PM
