Results 1 to 8 of 8
Thread: What wood to use for a painted bookcase?
    Jun 2007
    New Jersey
    75
    What wood would you recommend I use for a bookcase which will be painted?
    Thanks
    Dennis
    Constantine, MI
    8,006
    Every time I've seen this question come up everyone seems to recommend poplar for those areas that must be wood (frames, etc.) and MDO or MDF for panels.
    www.wrworkshop.com
    Charlotte, NC
    1,487
    A agree MDF for the panels.
    WNY, Buffalo Area
    873
    If you want a hardwood, go with poplar. I you want a soft wood go with pine. Either will paint well, and at a reasonable cost.
    Poplar is very common for painted projects. Most people don't like how the greenish tint of the wood finishes with stains.
    MDF is fine for painted panels. If you are planning on raising the panels make sure you have good dust collection at you router table/shaper. The dust created from routed MDF is terrible, and terrible for your lungs.
    The only time where I have heard MDF to sometimes be a questionable choice, is in a damp setting. It probably depends on how or how well it was finished, as to how it holds up.
    www.tinyurl.com/thewoodshoppe
    Houston, Texas
    2,323
    Quote Originally Posted by Dennis Thompson View Post
    Thanks
    Dennis
    I would build the boxes out of construction/paint grade birch veneer core plywood and cover the visible end grain of the plywood with poplar. Molding can be finger joint/paint grade pine. Back to help retain squareness I would use 1/4" or 6mm birch good one side. If it is worth the effort to build it, it is worth the cost to make it better ( even if it is paint grade).
    But....... it is your project and it is your choice, you know your budget, just do the best work you can.
    Shaz
    Please join me. Register now.
    Shaz
    Here is how
    I agree with most of what others have said with one caveat, make sure you get the right thickness/type of wood for the span of the shelves. Check out http://www.woodbin.com/calcs/sagulator.htm for making that calculation particularly if the unsupported shelf span is over 18". Larger spans may require something other than poplar and/or thicker wood than you might imagine especially if they are going to carry books or other heavier objects.
    I've used poplar and MDF with good results. And Chip noted a good resource for those of us that can't calculate a load from experience. I used the sagulator for a set of shelves and it prevented a big mistake.
    Wes
    Indianapolis area
    1,697
    I'm surprised that no one has mentioned using poplar and MDF. That's what I would use.
    ________
    Ron
    "Individual commitment to a group effort--that is what makes a team work, a company work, a society work, a civilization work."
    Vince Lombardi
  1. Suggestions for sealing exterior painted wood crafts
    By Angela DiFalco in forum General Woodworking Q&A
    Last Post: 11-09-2013, 01:23 AM
  2. Painted me car
    By Roger Tulk in forum Off Topic Discussion
    Last Post: 10-25-2012, 03:00 PM
  3. painted cabs
    By Stephen Bellinger in forum Flatwork Project Showcase
    Last Post: 05-07-2011, 10:02 PM
  4. Painted cabinet
    By Dan Thibert in forum General Woodworking Q&A
    Last Post: 05-05-2009, 01:09 PM
  5. Painted Kitchen
    By Duncan Cheslett in forum Flatwork Project Showcase
    Last Post: 09-24-2007, 10:46 PM
