Results 1 to 10 of 12
Thread: Begets
    Begets
    Yes, "begets" not "Regrets".
    I just installed my newest toy - the Biesemeyer fence/table I picked up at Lowes. It went together very well. I am astonished how well my old Rockwell/Delta contractors saw was set-up. Everything lined up great! Things would have gone faster and been a bit easier if I had the room to move things without needing to move other things first. My only modification was to drill a countersink on the back side rail to accommodate the spiral rivets used to hold the original ID tag on. I could not bring myself to remove the tag - it's just too sacrosanct.
    Well, I digress a bit. My post was about "begets". Now that I have the new fence system installed, I took stock of the situation. And this is when the begets begin. So, the Beis is installed, which begets the overhaul of the dust collection ducts. It also begets reworking the compressed air piping as well as the relocation of some tools and tables to make room just to move. And to move the table I need to . . . . And it goes on.
    But it's installed and square. I figure a few weeks before the sawzall is out hacking off the last 6" hanging off the left end. It always got me at work and now with the tighter conditions, I'll be a hurting puppy (yes it hits right there)
    The fence does bring back memories of good times in the shops at work. And it's bringing out old habits I hadn't used in s few years.
    Anyway, the new fence makes my little saw look even smaller and a little more worn than I ever thought. But it will be a great addition to the shop.
    Wes
    Tokiwadai, Japan
    2,882
    Wes!
    Looks good on that saw, and we both know you're really gonna enjoy it.
    There are probably more "begets" that you haven't thought of yet.....but you'll find them soon enough.
    15,815
    Wes that looks great!
    The top of your table saw is almost as big as my workbench
    Nice upgrade!
    5,378
    Instead of cutting the left side off, why not just move the tube one set of mounting holes to the right? That way, you'll gain about ten inches of rip capacity to the right. You'll need to install a new measuring tape, though.
    ďThe opposite of bravery isnít stupidity, itís conformity. Even a dead fish can go with the flow.Ē
    Roy Underhill, 2018
    he`d have to renotch for the miter slots too.
    Jim,
    Moving the tube only might be an option - though I would need to drill some new holes etc. At this point, I hate to change anything because the whole system bolted on so well and was right on the money accurate. I used a Starrett rule to measure everything and have been impressed with the adjustment right out of the box. I hate to do something (which we all know I would) that would mess that up - right now that is.
    Even if I moved the bracket I'd need to re-drill to mount it and as Tod suggests might even need to re-cut the miter notches.
    I'm going to use it as is, and if I - or when I hurt myself on the tube I'll address the issue. I am going to need to reassess the layout of the shop since the width of the machine is around a foot wider - a foot I really don't have where it's placed right now.
    Gee, maybe I need to make something with all these neato new tools?
    Wes
    5,378
    Quote Originally Posted by Wes Bischel View Post
    Jim,
    Wes
    Wes,
    Unless the design has changed in recent years, the mounting holes in the bottom of the tube are evenly spaced, about 10" or so apart. Unbolting the tube from the angle iron, and moving it over by one set of holes, lets you just bolt it back up (using one less bolt) and you're back in business.
    Add a new stick-on tape, and you're done. You do lose some left-of-blade capability, but in my case, I've never missed it. I virtually never had the fence to the left - even when I could...
    A minor added advantage is that the small, unused part of the angle that's now to the left of the tube makes a great place to keep the remote for the dust collector.
    Roy Underhill, 2018
    Jim,
    I went down and checked the bolt pattern and spacing. It does seem to have changed. It is now a 2, 1, 2, 1, 1, pattern and the spacing isn't even between any of the combinations - at least the ones I came up with. Even with shifting it over, it solves the personal injury issue, but the saw is against the wall, so it will necessitate moving the saw out. I'll use it for a while and see what comes up.
    Thanks for the suggestions and help.
    Wes
    2,784
    That looks great Wes. I just made my final pilgrimage this afternoon and finally found one. Open box. but all the major components look to be in great shape. Price was certainly right! Now to find time to put it on the saw! I'll probably mount the rails all to the right of the saw. I'll post pictures when I get-r-dun! Jim.
    Coolmeadow Setters...
    Exclusively Irish!
    Albuquerque, New Mexico
    1,099
    Wes, a Sawzall would be far more invasive than just moving the tube one hole set down. As Jim said, it would then be a simple matter of installing a new tape.
    Youíre going to love the Bies
    friend...if you have one."
    one."
