Bruce Page
- Albuquerque, New Mexico
If you wanted to coax a slightly out of flat board straight(er) using water only, which side would you dampen, side A or B?
Yup, B
If it's crooked, it's gonna stay crooked, though, like Jim said. It'll just go back to crooked once it dries.
Ian wins the thread.I wouldn't dampen either side. Wet wood is not gonna burn nearly as well.
Thanks guys,
My problem is with the lower left corner of the right door. The doors were dead flat when I made them earlier this year but now the lower left corner of the right door has warped out about 3/32”. The door is pretty big so it takes very little pressure to straighten it out. I can probably install a latch or something to hold it in position but it still frosts my butt!
I was hoping that I could coax it straight again but I guess not….
Chris, I already gave that a try. I left it clamped for almost 2 weeks, when I unclamped it, it sprang into perfect position! But 2 days later it wasn’t…a cabinet maker i used to work for had a trick to fix warped doors on site. if a door was so bad he couldn't adjust it out using the hinge (talking overlay doors not inset) he would use this trick. let's say the bottom corner of the door sticks out too far, he would place a 1/2" thick block between the upper corner and the face frame, then clamp the lower corner to the face frame, then leave it there overnight, this would force the door to over compensate in the opposite direction. it actually worked. not sure if it stayed that way, as he would finish the install and never go back unless the homeowner called to complain about something.
but i guess that latch system looks like it would well pretty well.
i know some of the "high end" cabinet makers on the net that do nothing but inset doors use those magnetic latches on top and bottom of the door openings.
good luck with the latches.
chris
Bruce - sorry to be flip. I can imagine your frustration. But this is wood. The 3/32" are proof that its real wood, not some plastic covered facsimilie. I hope that one of the clever guys can give you some real help but I'm afraid I can't. In my world (outdoor furniture) I know that if it gets outta line its likely to stay outta line. That is why anything "lively" gets burned or cut into shorts.
........maybe in the winter it will go back to the right shape?
