Results 1 to 10 of 14
Thread: Deft lacquer, can you spray it??
    The Heart of Dixie
    4,268
    One draw back to small town life is the lack or access to 'stuff'. BORG does carry Deft Lacquer but that is it. Can says not to thin or spray it. Just to brush it on. Being the curious person I am I want to know if anyone has tried spraying it?
    I wanted to prefinish the raised panels before assembly. I have a spray can of Deft and was going to just do the panels with that. Then spray the final coats on when it was finished. Then I read where it says not to spray it.
    I do have a Sherwin Williams not to far away, but I am still Curious.
    Custom built boats and Kits
    810
    Not Deft, but an analogy .... we recently started to repaint our basement. The HD carries a line of concrete sealing paint. The instructions for the "average user" say to not spray it. But ... on the website, the instructions for the pro give the various nozzle sizes for the various professional airless sprayers ... including mine . gWe sprayed - worked well. Why not give 'er a go on a chunk of waste and see what happens? It seems to me that my radio restorer buddies spray Deft, but I'd have to search a couple of websites for the evidence.
    jeff, if it`s real lacquer then it can be thinned and sprayed...if it`s waterbased....you`re on your own..
    The Heart of Dixie
    4,268
    Couple of people over at Woodnet said they spray it. So I will do the raised panels with the spray can before I assemble them. Then I can spray the whole thing once it's all together.
    Cool
    Deft is what I have always used,and have always sprayed with regular paint gun. Hope this helps! Later P.S.-Thin with lacquer thinner!!!
    Villa Park, CA
    1,407
    The problem with spraying Deft brushing lacquer is that they put retarded in the brushing lacquer to keep it from drying too fast. When brushing it, you want it to flow out before drying to get rid of the brush marks. That makes it more difficult to spray on a vertical panel - it runs unless you're very careful.
    Even on a horizontal panel, it takes longer to dry which means more time for junk to settle on it.
    But I have to question why you want to use lacquer. If you're doing cabinet door panels for a kitchen, for example, why not spray polyurethane? You can even use water based poly. The advantage of poly is that it holds up better in wet. You might say, "But these are doors and they won't get wet." What happens it that people have wet hands from the sink and they open the cabinet doors. The top of the door (on the bottom cabs) starts to wear out from the constant wetting.
    But if they're your doors, and you know what's happening, just sand the top of the door lightly every couple of years and brush (or wipe) on more lacquer. Where that fails is if you stain the doors. Every time you sand them, some of the stain comes off and it gets noticeable.
    Anyway, I like lacquer for furniture that doesn't get a lot of wear or wet and poly where you have wear, heat and/or wet. Also, if you're looking for a real high shine, lacquer rubs out much better than poly.
    So they both have their places.
    Mike
    Ancora imparo
    The Heart of Dixie
    4,268
    Thanks Mike, but I am not a poly kind of guy. I know it's improved but I still see that plastic look in my head. I much prefer Shellac, thats my favorite. But this is a wine cabinet for my sister so can't use shellac. So it's lacquer or varnish for it.
    Thanks for pointing out about the retarder. That makes a lot of sense.
    Austin, Texas
    1,461
    I agree with Mike... I have always heard that Deft had a bunch of retarder. But I disagree with Mike about using Poly on cabinets. I love poly for floors, but hate it for other uses.
    Deft is Nitrocellulose lacquer. I did a bunch of tests on NC lacquer with alcohol, kitchen soaps and foods, etc., and it worked well. Then I left a wood piece near the kitchen sink for a few days and it got spots that I couldn't get out. Learned that NC lacquer was not approved by KCMA - Kitchen Cabinet Mfg. Assoc. Catalyzed lacquer is approved. (Both plain and catalzyed lacquer are routinely available from Sherwin Williams, but it always seems to be kept in the back room.)
    But I took the leap from NC lacquer direct to Target USL spray Lacquer (after being pushed by lots of different woodworkers). It is mail order only, so it doesn't matter where you live. And it has better KCMA ratings than catalyzed lacquer. I am getting ready to order my next 5 gallon bucket, I love it so much. I have a web page on it - see www.plesums.com/wood/tips/waterbase.html
    Charlie Plesums, Austin Texas
    Villa Park, CA
    1,407
    All of finishing is a matter of opinion so you should use what you feel comfortable with. Lacquer for a wine cabinet should work well. And if you want to put a real shine on it, you can rub it out.
    Regarding poly and shellac, I'll give my opinion - for what that's worth. I'm not a big fan of shellac. It doesn't hold up to water or alcohol. If someone sets a wet glass on a table finished with shellac, it will leave a ring. Commercial furniture makers gave up on shellac a long time ago (maybe the 1920's). Those coasters that everyone uses for drinks are a leftover from shellac finished tables. Today, commercial furniture is finished with catalyzed lacquer and you can't hardly hurt that stuff - water, alcohol, heat (up to some limit) has no effect on it. It doesn't even chip very easily.
    Modern poly is pretty good stuff. It doesn't shine like lacquer but it definitely doesn't look like plastic. In my opinion, it just looks like lacquer but just a bit duller in finish. For a kitchen table, poly is a good finish if you can't use catalyzed finishes. Shellac would never hold up with the water and heat that a kitchen table gets. Lacquer is better, but it melts when heated so if someone puts a pot or hot dish on the table, you get a mark from the lacquer melting.
    The only thing I use shellac for is as a sealer (dewaxed shellac) - and then I put my final finish over the shellac. Shellac is good in that application because you can put any finish over it since it's alcohol based. Water based or solvent based finishes don't melt the shellac so your surface prep (stain, etc.) stays the way you did it.
    But anyway, as I said, it's all an opinion, and that's my opinion.
    Mike
    [I hadn't seen Charlie's posting when I posted the above. Charlie has lots of good experience (more than me) and I would go with his recommendations.]
    Ancora imparo
    Houston, Texas
    2,323
    Spray lightly and more times on the vertical. Spraying with deft allows you to brush out the runs, ( if you spray heavy) the same with poly urethane.
    Agree with Mike and Charlie.
    Good luck.
    Please join me. Register now.
    Shaz
    Here is how
  1. Lacquer over oil
    By Chris Krohn in forum General Woodturning Q&A
    Last Post: 05-18-2009, 12:49 PM
  2. Lacquer brush or spray
    By Bill McQueen in forum Finishing School
    Last Post: 04-15-2009, 02:44 PM
  3. Wax after Deft
    By Bob Wiggins in forum Finishing School
    Last Post: 01-27-2009, 04:53 AM
  4. Deft Laquer / Arm-A-Seal / Seal-A Cell.
    Last Post: 09-24-2007, 01:42 AM
  5. where is the lacquer?
    Last Post: 08-24-2007, 03:30 PM
