Results 1 to 4 of 4
Thread: Anybody make a 5" Compound Angle Dust Port?
    Waterford, MI
    773
    I'd like to put a 5" port on my MM16 that's angled downward as well as rearward (towards the outfeed table side) so as to keep the hose from jutting out in the standing path of the table. John has something similar on this thread but he fabbed his.
    http://www.sawmillcreek.org/showthread.php?t=60267
    My welding tools and skills are non-existent plus I dont need any more side-projects at the moment. I'd rather just buy something if it exists.
    Cant tell for sure from his pics whether his is a compound angle or only bending downward. Anybody already make something like that? Either metal or plastic?
    Floydada, Tx
    1,941
    This is what I would do, First you need a peice of cardboard, 1' peice of 5" stove pipe and some rivets. Now to figure out the whay to cut the pipe I would cut a hole in the cardboard the size of the pipe. Then set the pipe in the hole out the angle you want the pipe. Now slide the pipe thru the cardboard untill you have the length you want plus a inch. Trace the pipe with black marker and then you just need to cut tabs all the way around the pipe. Then cut the hole in the machine where you want it. Put the pipe thru the hole and bend over the taps and drill the hole for the rivets and install the rivets. Now you have a new dust port. with out welding.
    Thomasville, GA
    6,060
    Can't you use an adjustable elbow? That's what I did on my bandsaw. Works fine.
    Bill Arnold
    Sep 2007
    Central (upstate) NY
    1,457
    I agree with Bill - an adjustable elbow came to mind when I read your post. You'll be able to make whatever angle you want overall and then rotate it to point in whichever direction you want.
  1. "New" Stanley Sweet Heart #60 1/2 Low Angle Block Plane Mini Review
    Last Post: 11-30-2009, 03:19 PM
  2. Hitachi C10FCH2 10" Compound Miter Saw
    By Rennie Heuer in forum Hot Deals
    Last Post: 07-22-2009, 02:36 PM
  3. bandsaw dust port question
    Last Post: 06-20-2009, 02:36 PM
  4. Compound angle in SketchUp
    By Ron Fritz in forum Designs, Plans and Sketches
    Last Post: 02-25-2008, 04:29 PM
