Stuart Ablett
- Tokyo Japan
Well, I guess this fits in this forum....
I'm always stuck for space, and every little bit extra I can squeeze out of the Dungeon is a good thing.
My compressor has sat in the NE corner of my shop, one of of the concrete table tops I have in all 4 corners of my Dungeon (they are the tops of the L-O-N-G concrete fingers that go deep into the ground keeping the building in place). Well there is a fair bit of space above the compressor, so last night I made it levitate a bit............
This is what it looked like before (with all the usual stuff that seems to end up on any flat surface removed )
and this is how it looks now.........
The boxes are all good and solid, and they will be anchored into the concrete (later today, as I did this starting about 1 AM, so hammer drilling into the concrete was NOT going to happen at that time )
I've still got to plumb the drain again, I need to rethink that a bit, but all in all I'm rather pleased with it.
I know some of you guys are not hurting for space, but I sometimes think of my self as a submariner, in that my space is very limited, and I have to use it the best way I can, this freed up some very useful space!
