Results 1 to 8 of 8
Thread: Ramone burl and Blackwood
    Sep 2007
    Brookhaven, Ms
    64
    This came from an offcut of a small chunk of Ramone burl that I've had laying around for a while. Added a Blackwood pedestal that didn't work out on another project. 2 1/4" diameter by 6 1/4" tall, buffed Antique oil finish.
    810
    I really like that !!! The top looks like seashell and the whole assembly has a air of delicacy about it. Nicely done !!!
    cheers eh?
    30,225
    Very cool, Travis. Very elegant piece for a using leftovers. I'm assuming you used a vacuum chuck to reverse the bowl part and remove the tenon. Is that the case?
    Goodland, Kansas
    4,834
    Wow Travis that is another cool one. Excellent wood and pedestal. Well done.
    Bernie W.
    Sep 2007
    Brookhaven, Ms
    64
    Vaughn, none of my vacuum chucks are that small. I just turned a close fitting friction drive from a piece of scrapwood. I taped the mouth to the friction drive with blue painter's tape to turn the mortice for the pedestal tenon and finish off the bottom.
    Brentwood, TN
    294
    Hey Travis, great looking piece! Could you expound a bit on the finishing technique? Also, when you use "black wood" do you have to add ebonization or is the wood dark enough to begine with? What did you use to do the hollowing on the cup portion?
    Member; Society of American Period Furniture Makers
    Kutztown PA
    252
    I like it Travis, and it gives me some ideas for some offcuts of curly cherry from a piece I turned recently. They are too good to throw away and almost too small to be something by themselves.
    Bill
    Bill Grumbine
    www.wonderfulwood.com
    Sep 2007
    Brookhaven, Ms
    64
    Chris, I used 2 coats of Minwax Antique oil, then buffed with the Beall wheels after it cured. The Blackwood is natural, no coloring added.....just sanded to 2500 grit and Mylands friction finish, then buffed. As for the hollowing, I used the scaled down Jamieson style setup that I made for my mini lathe, with a John Jordan 1/2" curved bar and various home-made 1/2" bars/scrapers.
    I know the feeling Bill, I can't bring myself to throw anything away that I "might" be able to use.
  1. Blackwood
    By neil mackay in forum General Woodturning Q&A
    Last Post: 04-12-2010, 01:50 AM
  2. Ramone Burl
    By Mark Cothren in forum Lathe Project Showcase
    Last Post: 12-02-2009, 01:09 PM
  3. Replies: 12
    Last Post: 04-07-2008, 04:33 PM
  4. Buckeye burl and Blackwood
    By Travis Stinson in forum Lathe Project Showcase
    Last Post: 10-25-2007, 05:40 PM
  5. Red Gum and Blackwood
    Last Post: 09-19-2007, 01:49 PM
