Results 1 to 10 of 11
Thread: Legs with cores **PICS added**
    Kansas
    417
    I am making some square legs, 4 pieces with 45 degree cuts. Plans call for a core to fill the hole in the center.
    Does the core have to be the same type of wood as the legs themselves? Plans call for it but I would rather not since it will never be seen, but I will if I need to because of wood movement or something. Oh btw, I need the cores for mortise and tenon joints into the legs.
    Thanks
    Rise above the rest
    Charlotte, NC
    1,487
    Seems to me that filling the core defeats the purpose of mitering the 4 sides! Are you supposed to just fill where the MT's go? You will probably want a wood that would have similar movement as your primary wood, but outside that, I don't think it matters.
    Kansas
    417
    Quote Originally Posted by Ed Nelson View Post
    The core is the length of the leg, it will be completely solid when done.
    Rise above the rest
    Ridgetown, Ontario, Canada
    726
    fill it up with short scraps, defective pieces with knots, etc.
    hobby woodworking since 1972
    2,784
    I'm going to read a little between the lines on Ed's post (If I'm wrong here Ed, I beg forgiveness now ). Why not make the legs solid to begin with? Unless they are huge in diameter, I'd think a solid piece if available and not too outrageously priced would be the way to do this. To me the continuous grain of 1 solid piece of wood would be more appealing also.
    Now with that said, what is the reasoning behind building the legs as you have stated? I'm guessing that there is a good reason I just don't know or understand. Thanks! Jim.
    Coolmeadow Setters...
    Exclusively Irish!
    Kansas
    417
    Quote Originally Posted by Jim O'Dell View Post
    Legs are made out of 3/4" stock, the dimension of the outside is 2 1/4", with a 45 cut that leaves 3/4" on the inside, which when put together leaves a 3/4" square that needs filled up.
    Yes it might be more appealing and I even thought about doing that, but I already had the stock and the pieces are cut. Making the legs with 45 cuts doesn't shown any end grain at the corners.
    Rise above the rest
    Austin, Texas
    1,461
    If I were you, I would fill the top where the tenons go, if anything, but not bother with the rest of the leg. We are looking at bending/twisting forces on that part of the leg, and virtually all the strength is based on the outside, not the core (the third power of the distance from the center). IMHO the overall weight of the leg, and the internal tensions, would outweigh the value of the solid core.
    I made some solid legs, with a taper, recently. If I were doing it again, I would glue up any wood, then veneer the outside for the show grain. You could see the glue lines in my legs, especially on the taper, and the grain wasn't as pretty as some shop-cut veneer would have been.
    Charlie Plesums, Austin Texas
    Kansas
    417
    Quote Originally Posted by Charlie Plesums View Post
    I might give that a shot, I believe it only has two tenons. Yeah, I am little concerned about the way it might look as far as the grain on each side not matching, but that's what makes wood projects unique I guess is the different looks. Since its not a "fancy" piece of furniture I think it will be okay, hopefully it will just give it some character.
    Thanks for all the help.
    Rise above the rest
    11,900
    Your question begs the question: Why?
    A plug/tenon at top would seem sufficient.
    If you simply want mass and weight, fill with lead shot.
    Kansas
    417
    This is the two shorter legs glued and clamped up.
    This is the longer legs that I will glue tomorrow.
    Rise above the rest
  1. Here we go again buy or build? Pics added 4/12/13
    By Chuck Thoits in forum Flatwork Project Showcase
    Last Post: 11-30-2014, 01:51 AM
  2. NEW TOY!!! Pics finally added
    By Tom Niemi in forum Neander Tool Questions and Show & Tell
    Last Post: 10-12-2011, 08:14 PM
  3. How long for DNA Pics added
    By Chuck Thoits in forum Turning Tool Questions and Show & Tell
    Last Post: 02-26-2011, 02:04 AM
  4. Ok here is a stripping ? pics added
    By Chuck Thoits in forum General Woodworking Q&A
    Last Post: 01-16-2011, 05:32 AM
  5. Getting closer pics added
    By Chuck Thoits in forum Old Iron
    Last Post: 12-31-2009, 02:49 AM
