Results 1 to 10 of 11
Thread: Pnuematic Staplers...any woodworking uses?
    I just bought a small 18 guage staple gun. It shoots a staple wide by 1 inch long which is perfect for nailing on cedar shingles onto the side of your house. I figured if it does only my cedar shingling, it would have been worth it.
    But as easy as this thing works, I was wondering if it has any woodworking uses? Other than putting a new seat fabric on my snowmobile seat and a few other carpentry rated uses, I cannot think of much else it could be used for.
    I was just curious if other woodworkers have a staple gun like this and what they use it for. Surely there must be some use for it in woodworking?
    810
    Nahm just had an episode on TNYW where he used a stapler just like you've decribed for making the connector between the slats and the control rod on a set of window shutters.He made a jig that held both the stapler and the slat and when he fired it, the staple went exactly the correct length into the slat.
    cheers eh?
    Tokiwadai, Japan
    2,882
    Travis,
    What size range of staples will it shoot? Probably some trim and cabinet/furniture work it might do....
    30,225
    I have a cheap Delta brad nailer/stapler, and I've used the stapler for building shipping crates for a few of my bigger cutting boards. I haven't made any real "woodworking" projects that could use them, but for simply slapping a few pieces of lumber together to make a durable box, the staples were handy.
    I used mine for the trim in my garage - it's taken a beating. Also for crates and boxes and jigs - functional work only!
    Wes
    Odessa, Tx
    1,813
    Jigs, Cabinet backs, screw/small parts boxes, and even for some glued shop/storage drawers.
    Travis, the narrow crown staplers aren't really the best for upholstery, they are a little too narrow and cloth/vinyl will tend to tear out pretty easy. The upholstery staplers use a wider crown staple.
    a 1/4 crown stapler is great for cabinet backs, thin-paint grade mouldings(think door casing on the jamb side) and any wood to wood connection where you`re worried about a slight or finish headed nail pulling through.
    because most 1/4 crown guns where designed to shoot the fastener flush or slightly below the surface they don`t work for thin materials.(like upholstry)
    (grinding the nose with a beltsander will fine tune the countersink deapth)
    Thanks guys, I was just kind of curious.
    I redid the upholstery on my old snowmobile and it was a bear. By the time you pulled the fabric tight, then tried to drive a staple into the plastic carcass of the seat, well it was almost impossible. I was thinking maybe the pneumatic one would work better. Probably not.
    That's too bad. My new snowmobile...my pride and joy that certainly outranks both Patty and Alyson (well maybe not) needs a new seat. I was moving my generator around and ended up putting a puncture hole through the seat. I try to keep my sled in tip top shape so now it means I need a new seat cover. I tell you, snowmobiling is one expensive hobby!!
    30,225
    Quote Originally Posted by Travis Johnson View Post
    ...my pride and joy that certainly outranks both Patty and Alyson...
    I'm guessing if Patty sees that, you'll be the one needing the new seat cover.
    travis, i keep a paslode upoholstry stapler for fastening stuff that`s too fragile for a 1/4 crown....if memory serves(?) i paid less than a hundred bucks for it, and a box of 80 gazillion staples is under 25...they`re like lots of tools, handier than a pocket on a shirt when you need it.
  1. This is NOT woodworking
    By Leo Voisine in forum Off Topic Discussion
    Last Post: 10-21-2014, 07:29 AM
  2. Popular Woodworking & a Family Woodworking Member
    By Bill Satko in forum General Woodworking Q&A
    Last Post: 11-26-2013, 03:27 AM
  3. Not just woodworking
    By Ryan Mooney in forum Off Topic Discussion
    Last Post: 08-17-2013, 06:53 PM
  4. Woodworking plans - Which is the best woodworking guide?
    By john lee in forum General Woodworking Q&A
    Last Post: 07-10-2010, 12:29 AM
  5. Woodworking Yes or No ??
    By Brian Pilon in forum Off Topic Discussion
    Last Post: 03-07-2007, 08:10 PM
