Results 1 to 10 of 12
Thread: Shaper questions
    3,083
    Shaper questions
    I have both a shaper with a 1/2" arbor & a shaper with a 1" arbor.
    I see shaper cutters with a 3/4" arbor hole is it possible to use a sleeve to increase the 1/2" arbor up to 3/4" to use a cutter with a 3/4" arbor hole?
    Is this cutter made to be used so that it can be used to round over either a 1/4" or 1/2" edge & how would it be used. As I was looking at it it only turns one way so it can't be turned over. Would it be used under for one size & over for the other size?
    http://www.grizzly.com/products/C2004
    Is there a good place to buy at a reasonable cost both 1/2" arbored cutters for most of my hobby wood working as well as 1" arbored cutters when necessary.
    Thanks
    4,992
    bart,
    yes you can put a bushing into a cutter with a larger bore so it`ll fit your spindle, for bushings call cg schmidt.......as to the cutter you discribed?? i can`t picture what you`re talking about in my head.
    here`s a link to schmidt;
    http://www.cggschmidt.com/
    3,083
    Sorry Tod
    I thought I had pasted the URL.
    Southern Louisiana
    947
    bart, not tod, but best i can tell it looks like it is meant to either be turned over or just raised and lowered to achieve the needed radius.
    chris
    The Heart of Dixie
    4,265
    .....Is this cutter made to be used so that it can be used to round over either a 1/4" or 1/2" edge & how would it be used. As I was looking at it it only turns one way so it can't be turned over. .....
    I have that cutter. You flip it over and then you reverse the spindle rotation.
    Custom built boats and Kits
    3,083
    So I either buy another motor that is reversable or seperate cutters.
    Thanks
    Wake Forest, NC
    292
    FWIW, all of the 3/4" cutters I have bought have come with 1/2" bushings with them. Being that I only have a 3/4" arbor, I haven't used any of them.
    I will ship you a few if you want.
    3,083
    Quote Originally Posted by Steve Clardy View Post
    Do you have a 1/2 or 3/4 spindle for your shaper [what brand?] that has the 1" spindle? If not, maybe one is available
    Steve
    The 1/2" is Craftsman The 1" is a Davis & Wells.
    Southern Louisiana
    947
    ok, slap me on the head and call me stupid, but why do you have to flip it over and reverse it??? couldn't you just raise the bit higher and run the board under the cutter for the smaller radius? am i missing something??
    chris
    3,083
    Quote Originally Posted by Chris Mire View Post
    chris
    It may be because its considered safer to run the cutter under the material instead of over the top.
    Am I right here guys?
  1. Little shaper
    By Rennie Heuer in forum Old Iron
    Last Post: 07-06-2015, 03:29 PM
  2. shaper
    By ken lutes in forum Classified Ads
    Last Post: 08-15-2012, 01:12 AM
  3. Elementary Router versus Shaper Questions
    Last Post: 11-29-2010, 01:01 AM
  4. my jet shaper
    By Dan Noren in forum Old Iron
    Last Post: 08-20-2009, 11:04 PM
  5. C-Man shaper
    By Al killian in forum Old Iron
    Last Post: 10-27-2008, 09:03 PM
